Old 08-01-2002, 08:09 PM
mattski mattski is offline
Air Conditioning smell!
After ~ 15 minutes of driving and AC use, I get this strange smell inside the car that I have never experienced before. It is not very strong but it is definitely there. A little acrid, acidic like.
Has anyone experienced anything like it?
What does refrigerant smell like? But if that was leaking, wouldn't it be gone after 2 months of use?
Could there be something dead in the duct work?
Mattski
97 LSi Ebony Pearl 130k Midlife Crisis
93 Legacy Wagon 180k Training Wheels
98 Outback 180k
98 Dodge Durango 120k Ski Bus
A multitude of skis to feed my need to go faster, faster until the thrill of speed overcomes the fear of death.
Old 08-01-2002, 08:29 PM
kuoh kuoh is offline
If it was something dead, it wouldn't wait 15 minutes to start smelling, especially if your car has been in the hot sun. Perhaps your blower motor is going out?
KuoH
Old 08-01-2002, 10:20 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Refrigerant has no smell, so you can rule that out (unless you're a farmer that likes using propane...) Does it smell like mold or midew? If so, let me know I found a bit of a cure. If it smells like a hot electric motor or melting insulation I think KuoH is on the right track.
Old 08-02-2002, 01:47 AM
scoochv scoochv is offline
It used to be that everytime I would near floor the car, the A/C would go warm and smell like that for 2-3 minutes or so. Then cold again. Took it back to the techie who said something about "overcharging" the freon (either before or after), anyway, he fixed it... But! I noticed it happen yesterday afternoon for some reason. So I'm thinking it's coming back?
Old 08-02-2002, 09:31 AM
I've always thought that if the power light comes on the A/C and fan shut off. (to maximize power)
Old 08-02-2002, 10:35 AM
Beav and KuoH, I have smelled burning stuff and this does not remind me of it. I don't know if I would recognize mold/mildew smell, but if you have an easy suggestion, I can give it a try.
Mattski
98 Outback 180k
Old 08-02-2002, 02:43 PM
Zeppelin's Avatar
Zeppelin Zeppelin is offline
Send a message via ICQ to Zeppelin Send a message via AIM to Zeppelin Send a message via Yahoo to Zeppelin
Try shutting off your AC a few minutes before you shut down the car.. Most AC systems will smell if you don't let them clean out..
I'm like a Slinky.. Not really good for anything, but you can't help but smile when you see me tumble down the stairs.
http://stickyvinylgraphics.com/
Old 08-02-2002, 02:51 PM
svxter's Avatar
svxter svxter is offline
Send a message via Yahoo to svxter
Re: Air Conditioning smell!
Odd you should mention that - I've noticed a smell something like mothballs on a couple of occasions lately. But it's not constant, and hasn't shown up the last week or so.
bill
Green 95 SVX - Cleo
Green 97 Outback - Maxine
Red F-150 Extended Cab Long Bed - Big Boy
Even the best monkey sometimes drops his banana.
Old 08-02-2002, 02:59 PM
Yeah, it is kind of like that only different.
I know what moth balls smell like. The similarity is that they both have a "chemical" odor.
Im going to try Zeppelin's suggestion and turn it off a couple of miles from home and let it "clean out".
Mattski
98 Outback 180k
Old 08-02-2002, 03:12 PM
vkykam's Avatar
vkykam vkykam is offline
The Road Less Traveled
There are products you can buy that sprays into the vent air intake that will kill most of the mold/mildew buildup.
Here at Crappy Tire (Canadian Tire), it's less than $20CDN for a can.
VK
Old 08-02-2002, 03:36 PM
Beav's Avatar
Not as old as Randy
Without me having to repeat a lot of stuff, go here ( www.airsept.com ) and read about the causes. I rec'd promo material from them but still no pricing - I hate companies that only give you pricing over the phone - grrrr. I saw on ad at amazon.com for a bottle that was supposed to do four cars and they wanted $160! Can you say "Owwww...take it out, it hurts?!"
Anyway I figured most bathroom cleaners have mold and mildew killing agents in them plus surfactants. I got a can of Lysol bathroom cleanser (but after having used it I wished I had picked something with a bit less perfume in it.) I drilled a small hole in the evap case under the dash - carefully and only deep enough to make the hole - you don't want to drill a hole through anything inside. I then found a spray can nozzle that had a straw and used it on the bathroom cleaner can, inserting the straw in the hole while the blower was running on medium. I flexed the straw all around in order to coat the evaporator evenly and after about half the can was gone I shut the blower off and let it sit for about fifteen minutes. Then I turned it back on high heat for a few minutes and let it set for an hour or so. The smell was gone! I used a small (short, too) screw to seal off the hole and made sure the evap drain was clear.
That was about 5-6 weeks ago and I can tell that the smell will be returning. I should buy one of the blower timers to dry the evap at each shut-down to eliminate the smell from returning. I just have to remember to call airsept on a day off - that is unless one of you EE types want to design a small unit with similar properties...
Old 08-02-2002, 04:11 PM
Boone
I was wondering why I do that. Must be ancestral memory from the early days of AC.
Old 08-02-2002, 06:22 PM
gcookaustin
On a really hot day, put the settings to "Econ" and turn the temp up as high as possible, and let it run for a while. Should clear it out (if it's moldy stuff).
Old 08-02-2002, 08:56 PM
Invisible avatar
Question
I don't recall ever having a "stink" or mildew odor from ANY automobile A/C system ever. Is there suddenly some bug going around similar to "sick" buildings? Are those of you experiencing this problem located in an ultra-humid climate? And since the subject is A/C, is it still recommended that the system be run a few times in the winter to keep the compressor lubed?
Cool hands Ron.
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 08-03-2002, 12:36 AM
DavieGravy DavieGravy is offline
Funny you should mension that. The smell's worse for me down here in California than Colorado.
Out for good.
