Old 09-19-2009, 07:27 PM
SVXalter's Avatar
SVXalter SVXalter is offline
Where to put Tach Sensor???
So I have my autostart fully installed. Everything works fine except when I remotely start the car it runs for a few seconds and then turns off... My guess is the tach sensor wire from the remote start module is not connected to the right spot. So my questions are:
1. Where do I connect the tach sensor? (currently I believe it is connected to a fuel injector wire)
2. Is there something else that could be causing this problem?
PS - The power door lock switches in our center consoles were made by Nissan haha. It says Nissan on the under side of it... I thought it to be quite funny.
-Dan
1996 Polo Green SVX L - 85k
1992 Ebony SVX LS-L - 193k (parts)
Old 09-20-2009, 06:36 AM
Re: Where to put Tach Sensor???
hi the fuel injector doesnt give the right count unless you can change it on you remote start ,the ecm creates the tach signal ,connector b61 pin 16 is yellow ,and subaru uses nissan and mitsub switches
Old 09-20-2009, 01:41 PM
SVXalter's Avatar
Where is it on the ECM? The ECM is big blue connector right? I've found diagrams and they really don't look too much like that connector. Would a negative spark plug wire work? I've tried many things with no luck. Starts and runs for a few seconds and then cuts out.
-Dan
Old 09-20-2009, 01:47 PM
sorry i looked up the wrong year car ,ill let you know
Old 09-20-2009, 02:03 PM
hi i dont have my 96 books home but i went i my alldata and they show the same thing ,4 yellow connectors at the ecm ,when i looked at the wiring a few days ago to see how the obd 2 cars differ it showed 4 yellow connectors
are you looking for the ecm at the left of the of the brake pedal behind the lower dash ?
charlie
Old 09-20-2009, 11:37 PM
SVXalter's Avatar
I believe I was looking at that same ECM... The big blue harness? No matter now though, I tried both spark plug wires not knowing which was which and got it on the second try. I believe it was the yellow wire coming off of the spark plug.
Everything is fully functional after a very long install.
-Dan
Old 09-21-2009, 12:30 AM
Banned
what system did you install, would you mind if I probed you a little for answers???
Old 09-21-2009, 05:26 PM
SVXalter's Avatar
I installed the Astrostart Astroflex 4100. I wouldn't mind at all. It's always nice to make things easier.
-Dan
Old 09-22-2009, 12:22 AM
waiting for your how-to.....
and my auto start to arrive
