Old 08-20-2009, 05:15 PM
michael's Avatar
michael michael is offline
What Potholes ???
Parts compatibility (Legacy 1996-1999)
I wanted to start a thread that could lead to a decent list of parts that you might find in a junk yard in relatively good condition. Since I and many others here maintain both an SVX and a Legacy or Imprezza we should be able to come up with a pretty good list.
1. Crank pulley
2. Door latches
3. Brake fluid reservoir cap
4. Oil cap
5. Air box & filter
6. Fuel filter
7. Alternator terminal boot
8. Rear wiper arm (TBD)
9. Battery hold down (TBD)
10. Power steering pump pulley
11. Timing belt idler (TBD)
12. Timing belt tensioner pulley/bolt (TBD)
Wanted: Steering Wheel
Old 08-20-2009, 07:30 PM
Re: Parts compatibility (Legacy 1996-1999)
1. Crank pulley
2. Door latches
4. Oil cap
5. Air box & filter my 97 Leg 2.2 uses a different filter
6. Fuel filter
11. Timing belt idler SVX will work on Legacy, but Legacy won't work on SVX
12. Timing belt tensioner, good for Legacy's up to 97
13. MAF, Leg will work on the SVX but you lose some of the top end.
Old 08-21-2009, 10:24 AM
s'ko s'ko is offline
14. Alternator
15. Starter
16. Timing belt tensioner
17. Knock sensors
18. Oil pump
19. Fusible links
20. Fuses (duh)
21: ABS sensors, possibily the ABS pump
I would venture to guess that the Lego-Imp Power steering pump would work as well. The mounts are the same.
Timing pulleys and gears for the EJs are shorter than the EGs. They will work in a pinch, but the timing belt is the same width as the pulleys and gears so there is no margin for belt travel.
Old 08-21-2009, 04:21 PM
michael's Avatar
What Potholes ???
1. Crank pulley
2. Door latches (on the body)
4. Oil cap
5. Air box & filter
6. Fuel filter
13. MAF (but you lose some of the top end)
14. Alternator - doubt it
15. Starter - also doubt it, A/T anyway
16. Timing belt tensioner (TBD)
17. Knock sensors (TBD)
18. Oil pump (TBD)
19. Fusible links
20. Fuses
21. ABS sensors (TBD)
22. Center timing belt cover & seals (TBD)
The radiator and fans look promising, ABS pump - no way, PS Pump maybe. If someone
with a lot of mechanical experience could ditch some of those TBD's I'd appreciate it.
Old 08-21-2009, 04:26 PM
SomethingElse's Avatar
word words wording
There are probably more in this thread
http://www.subaru-svx.net/forum/showthread.php?t=32422
Eric
Old 08-21-2009, 07:30 PM
Originally Posted by s'ko View Post
14. Alternator
15. Starter
17. Knock sensors
18. Oil pump
19. Fusible links
20. Fuses (duh)
The alternator is different, the electrical connectors match and you can mount it in place, but the mounting tabs are cast in a different position and the pulley won't line up with the others.
Old 08-21-2009, 07:58 PM
michael's Avatar
What Potholes ???
Thank you. Don't know how I missed that one
1. Crank pulley
4. Oil cap
5. Air box & filter
6. Fuel filter
14.
18. Oil pump (TBD)
19. Fusible links
20. Fuses
Old 08-21-2009, 09:07 PM
1. Crank pulley
4. Oil cap
5. Air box & filter (doesn't match a 97 2.2)
6. Fuel filter
12. Timing belt tensioner up to 97 Legacy
14.
16. Timing belt tensioner see 12
17. Knock sensors the connectors are different
18. Oil pump (TBD)
19. Fusible links
20. Fuses
Old 08-22-2009, 04:31 AM
michael's Avatar
What Potholes ???
Thanks all for your help with this. Dave, my 96 airbox looks identical is your close?
1. Crank pulley
4. Oil cap
6. Fuel filter
14.
16.
18. Oil pump (TBD)
19. Fusible links
20. Fuses
Old 08-22-2009, 09:39 AM
NiftySVX NiftySVX is offline
The knock sensors from the 1st gen legacy 2.2 are identical. The power steering pump is not interchangeable on the LS-L and LSi models as it is electronic vairable assist. I doubt the L and LS model pump is identical to any other, either. The starter is also SVX only. Many of the solenoids are the same, such as the purge control solenoid and I also believe some of the EGR components are the same. The fuel filter is interchangeable. A good way to tell is to look at the part numbers. a part with a "PA" in the middle is going to be either SVX only or designed for the SVX and then used for something else later. A part with AA in the middle is usually a common part. I forget the others but I think the impreza is "GA"
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 02-08-2010, 06:30 AM
I was doing rear brakes on my 97 Legacy this weekend. The caliper pin on the L side was seized and before I ran to the parts store, I decided to take a look on my shelves of SVX parts. To my delight the rear caliper and mounting bracket are identical
Old 02-08-2010, 08:54 AM
michael's Avatar
What Potholes ???
Good to know. I'm geting a parts legacy soon.
Old 02-08-2010, 12:02 PM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
O2 sensors are the same, but the Legacy only has one.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 02-08-2010, 05:40 PM
hi the starters do work on auto trans cars ,i use a mass air flow from a legacy ,i recorded both throught the full range with no difference but price
PA letters do mean svx but not allways ,GA were loyale ,FA is early impreza forester was FC
Old 02-08-2010, 05:59 PM
Gamesy's Avatar
Gamesy Gamesy is offline
anyone try comparing tie rods and that sub stuff?
