Old 08-05-2009, 09:40 AM
angrydan angrydan is offline
Rear Diff Problem?
Ug... not a good week for my SVX! First my mysterious gas problem, now this... on my drive in to work today, I started noticing a whirring sound coming from the rear of the car. It is definitely speed associated... I speed up, sound increases; slow down, sound decreases. It is not a high pitched sound. Based on a few searches around the site, it seems this is commonly associated with a failing diff. I've never had to mess with the rear diff before. Is there a dipstick somewhere back there to check the fluid level? Is it possible that if the fluid just got low it is still salvageable?
Dan Taney
1996 Subaru SVX LSi (Red)
2019 Subaru WRX LTD
Old 08-05-2009, 09:47 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Rear Diff Problem?
Could be a failing wheel bearing.
You can check the rear diff by removing the fill plug thats sits at the rear of the diff just about half-way up. Open it and see if any gear oil comes out. Ideally, a full diff will have a fluid level at the height to allow gear oil to just barely come out of the fill hole. If nothing comes out, dip a finger in there and see where the levels at and how dark it is.
Old 08-05-2009, 11:00 AM
If it is low, is that where i would add it? What type of oil is recommended?
Dan Taney
2019 Subaru WRX LTD
Old 08-05-2009, 12:56 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Yeah, you can usually just squeeze it right in from the bottle tip with a little maneuvering. A good 80w-90 hypoid gear oil is best, but if you dont know whats already in there, drain it completely and refill with all new gear oil so you dont mix 2 different weights..
Old 08-14-2009, 07:45 AM
Well, just to close this one off... I just got final word from my mechanic. It was definitely wheel bearings and NOT the differential! (Breathing a sigh of relief) Thanks for all your input on the issue!
-Dan
Dan Taney
2019 Subaru WRX LTD
Old 08-14-2009, 08:15 AM
Subie59's Avatar
Subie59 Subie59 is offline
94 SVX LSI Teal
Well Dan, no reason to be angry now..
94 SVX LSI
2001 LegacyGT (daughter's ride now)
2005 Legacy outback XT (wife's car)
all stock and likely staying that way for now
1981 Datsun 280zxturbo summer toy
