Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Brake Upgrades
Old 07-06-2009, 08:26 AM
the_paynter the_paynter is offline
06-07 WRX 4 pot brakes... FIT!
Well I finally took some time yesterday and tried my 4pot brake calipers / pads I had laying around on the SVX.
In short.... they DO fit.
In LONG...
The Caliper bolts on fine. The notch for the rotor needs to be sanded down (width wise) VERY little. (I did it with a piece of 80 grit sand paper) for the rotor to fit width wide. (it fits on without doing this but the rotor will rub on the caliper... you could just do this and drive down the road and it will fix it self but thats a little ghetto)
NOW... The big issue is you NEED to go to a slighly larger rotor (about 1cm bigger in diameter) and there is the proper amount of room on the caliper to allow this bigger rotor. You CAN use ur stock rotor but the pad sticks about 3/4cm over the top of the rotor. If you did use the stock rotors you would have to REMOVE this part of the brake pad as it would hang over as it wears.
If anyone can tell me a slighty larger rotor that fits the SVX hub i will try it out.
Pictures to come when i get home from class
I will also put up the part numbers
1992 SVX: JDM STI short geared 6-speed swap, COBB short shifter, slotted cross drilled rotors, Smallcar Clear headlight lenses, 1997 Grill.
1992 RHD WRX: EJ20G, 16G, Cusco Coilovers, Wilwood 4pot/2pot brakes, Defi Genome 60mm gauges, Exotic speed downpipe, 3.5" A'PEXi spec GT catback
Old 07-06-2009, 08:42 AM
Green1995SVX's Avatar
Re: 06-07 WRX 4 pot brakes... FIT!
How is this possible? I personally tried fitting these, and they weren't even close.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 07-06-2009, 09:05 AM
I had them on yesterday. They most definitly fit.
Im refering to the red ones not the BREMBOS... the Brembos definitly DO NOT fit, tried that first
Old 07-06-2009, 09:36 AM
BoxerFanatic's Avatar
This is very interesting... Those Subaru brakes are reported to be pretty good. I believe they were standard fitment on the late 90's 22B STI GC-chassis Impreza.
Any hope on the corresponding 2-piston rear brake calipers? are they anywhere close to fitting?
I wonder if the STI discs, or perhaps Tribeca discs, both being 5x114.3, would work for the increased diameter... but that is a common hub pattern, there are probably discs from another application that match SVX's dimensions, plus a bit of diameter... just a matter of finding them.
"What you plan, and what actually happens ain't exactly ever been similar..."
1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it.
2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan.
1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun.
Old 07-06-2009, 10:03 AM
sicksubie's Avatar
check the DBA catalogue
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 07-06-2009, 10:51 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
pics would probably help here
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 07-06-2009, 11:55 AM
sicksubie's Avatar
Get home from class?? Ditch class and get pics up 5 minutes ago... LOL
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 07-06-2009, 12:24 PM
taylorbr's Avatar
taylorbr taylorbr is offline
I've read theories on Legacy Central that the Tribeca rears would fit on our cars, but I've yet to have the time/money to try this out.
'93 Legacy LS (will last longer than the cockroaches)
'94 SVX LSi
Old 07-06-2009, 06:17 PM
i never thought of tribeca discs... they are a little smaller then STI ones and bigger then the SVX discs... have to grab a pair of these and try them out. uploading pictures now
Old 07-06-2009, 06:28 PM
Here ya go. Took it for a ride like this and it worked great but i took them back off until i get a proper size rotor
Old 07-06-2009, 11:04 PM
Wow, the disc looks barely narrow enough to fit through the caliper.
So perhaps as well as a bit more diameter, a mm or two less disc width might be good, too.
Old 07-06-2009, 11:54 PM
Thats what I was saying... it needs to be sanded down. This is PRE sanded, these were taken before any modification has happened. Ill being doing a full install write up with pictures when i install them.
I had to do the same thing when i put 06 2 pots on my old STI in the winter (winter set up)
Old 07-07-2009, 12:22 AM
Well i looked it up and the tribeca rotors are 12.4inchs (aka 315mm) Stock SVX rotors are 300mm i believe so this would give up an extra 1.5cm. This would increase the size of the rotor by 3/4 of a cm all the way around which should close up the gap a little. The only problem is the Tribeca rotors are suppose to be 30mms thick... where the SVX rotors are 26mms and already rub... dammit.
Well heres what I did FIND....
2004 Nissan Maxima (a34 model) has a 320mm rotor that is 26mm thick, its 5x114.3, and the bolt holes are 14mm (SVX is 13mm, i believe this play would be ok but correct me if im wrong)
Old 07-07-2009, 12:31 AM
alltrac alltrac is offline
Maxima
SVX
Victor
Old 07-07-2009, 01:57 AM
Originally Posted by alltrac View Post
Maxima
SVX
Victor can you post the ones of the Subaru BAJA?
