Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
Old 06-16-2009, 09:50 PM
Sanosuke's Avatar
Sanosuke Sanosuke is offline
Found a lost SVX
OBD1 upgrade to OBD2?
Has anyone done it? Is it possible? If so, please note if you can, what the major changes have to be?
:..Miharu..:(1994) Laguna Blue SVX 170k. MODs: Beat to shjt.
:..Fey..:2005 World Rally Blue Impreza WRX 80k and rising. MODs: Lowering springs, 22mm sway bars. SS brake lines.
Old 06-16-2009, 10:05 PM
Sov13t's Avatar
Sov13t Sov13t is offline
Re: OBD1 upgrade to OBD2?
Why
Old 06-16-2009, 10:48 PM
the_paynter the_paynter is offline
not sure why u would want this... doesnt ECUtunes chips only work with OBDI? As well I thought the hydra for the SVX was only OBDI as well could be wrong on that
1992 SVX: JDM STI short geared 6-speed swap, COBB short shifter, slotted cross drilled rotors, Smallcar Clear headlight lenses, 1997 Grill.
1992 RHD WRX: EJ20G, 16G, Cusco Coilovers, Wilwood 4pot/2pot brakes, Defi Genome 60mm gauges, Exotic speed downpipe, 3.5" A'PEXi spec GT catback
Old 06-17-2009, 07:25 PM
NiftySVX NiftySVX is offline
This would be an extensive modification, several of wiring harness are different, there are more oxygen sensors, and a few other things
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 06-17-2009, 07:49 PM
You would probably have to completely remove the wiring harness from the OBI car and take the wiring harness from an OBDII car and put it in. Its a ton of work as that would involve removing the whole dash as well as basically the whole HVAC system behind it.
I would have to agree with Sov13t and ask why you would want to do this. The OBDI system can be self diagnosed while the OBDII system you need to have a cpu reader, OBDI is able to be "chipped" while the OBDII is not(at least right now).
Old 06-18-2009, 09:08 AM
STeeL25T STeeL25T is offline
Soon to own a fuctional SVX
Send a message via AIM to STeeL25T
OBDI is perfered if your doing any mods to your car. The ECUtune chips dont work, the Hydra just recently became compatible with it (I think?). One of the reasons I sold my 96 and bought a 94 was to go to OBDI
