Rotor Replacement
What steps are required to remove the front and rear rotors. I replaced the pads today but still don't like how the car stops. I couldn't tell for sure how the rotors are held in place.
Re: Rotor Replacement
Take the front calipers off and the rotors will fall off.
back requires a little more because of the emergency brake, but when you look you will see! Is pretty much self explanatory. Good luck... If a problem, get back with a question ![]() Keith ![]() |
sorry... duplicate
I would hang the caliper with a big plastic tie.
![]() Keith ![]() |
I use a straightened out coathanger that hangs in the garage. Works wonders
92 LS-L, Ebony Pearl, 160k miles, sitting in the hospital waiting room hoping for a miracle 06 Hyundai Sonata GLS, 77K miles |
Fronts won't fall off if they're factory I don't think. I thought all Subarus from factory had that PITA screw holding 'em in which you can simply throw away as I've yet to see a set of aftermarket ones with the screw hold. If your rotors are just glazed and in good shape you can simply turn 'em.
British vehicles are my last ditch attempt to keep the nasty Italian thoughts in my mind at bay. So far its working. |
new ones are dirt cheap
probably cheaper than getting them turned. At least around here they are.
"Just glazed" rotors on our heavy-high-mileage SVX's would be nice!
To remove the rotors you also have to remove the caliper mounting bracket. On the rears I used a rubber mallet to break them loose and then they just pulled straight off.
1997 Boudreaux LSi 1994 SVX LSi(SOLD) Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3 |
Sorry for the confusion... I consider the mounting bracket as part of the caliper.
Keith ![]() |
Yeah, the caliper is two big bolts (14-16mm if I recall). Pull that off and the rotor should just be dangling there on the hub. If it's seized on, you can use a mallet if you don't want the rotor anymore, or you can use a bolt that fits in the little screwhole in the front of the rotor in order to push the rotor off the hub.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount ( ![]() silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear ![]() (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
17 maybe?
Keith ![]() |
Thanks.
I didn't see anything holding them on when I looked at them. Where is the PITA screw when there is one? I guess they are keyed in the back to the wheel hub and the silver cap which covers the hub can just remain in place from what you are saying. Right? |
