Old 05-25-2009, 02:00 PM
pearlm30's Avatar
pearlm30 pearlm30 is offline
How To Do the Bosch Relay Mod???
Hi
I did search for the bosch relay mod for my starting problem. I still cant find where I can buy this relay and where to mount it? I did see a wiring diagram.
Can anyone help???
BTW, I tried a new starter, a good ignition switch, new battery and good cable and I still have the click click no start symdrome.
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD
92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD
92 Teal SVX LSL lowered with Konig. SOLD
92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone
94 Red SVX L FWDwith LSL Leather Interior. SOLD
92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD
95 Polo Green........With Trany Problem. GONE
Almost complete Rear Wheel Bearings Job with Pictures in my locker
My Locker http://www.subaru-svx.net/photos/user.php?pearlm30
Old 05-25-2009, 03:17 PM
michael's Avatar
michael michael is offline
What Potholes ???
Re: How To Do the Bosch Relay Mod???
I cant help with your info but was wondering if your new starter was bench tested?
Wanted: Steering Wheel
Old 05-25-2009, 05:46 PM
I've heard the neutral safety switch can cause this problem. You should be checking the circuit with a multimeter to see where the voltage drop is.
The relay is a band-aid solution...but an effective one. There's a post a while back by Aredubjay explaining the relay. It shouldn't be difficult to find using the search.
Old 05-25-2009, 06:19 PM
Originally Posted by pearlm30 View Post
Hi
Can anyone help???
The relay is a Bosch 30 amp relay, used for horn, lights, etc. I would be available at most car part shops.
It is mounted down near the starter motor. Just screw it to the bulkhead, with the wiring going to the starter solenoid.
The wire to terminal 30 can come from the main terminal on the solenoid. The old wire with the spade terminal comes off the solenoid and plugs on to terminal 86. The new wire runs from terminal 87 on the relay to the spade terminal on the solenoid. Terminal 85 is connected to ground.
Old 05-25-2009, 06:21 PM
siceclipse's Avatar
siceclipse siceclipse is offline
just curious, what does this do?
Mike
1992 SVX LS-L Pearl White 102,000 miles (Gone)
2005 Evolution 8 SSL Tarmac Black (new daily)
1995 Eclipse GSX Durango Copper Pearl (teh beast)
276awhp/280awtq @ 18psi (560's inj)
260awhp/260awtq @ 17psi (stock inj)
Old 05-25-2009, 06:50 PM
It prevents the ignition switch, inhibitor switch, and wiring from having to carry the 30 amps of current that the solenoid needs. The relay carries the 30amps, the wiring and switches then carry only 0.100 amps.
All the switches last longer, and the starter works every time.
Old 05-25-2009, 09:59 PM
Bingo, and it works like a charm too.
Old 05-26-2009, 05:43 AM
dcarrb dcarrb is offline
I considered doing this to my silver SVX awhile back, then the problem (which happened only rarely) went away... until a few days ago.
What role does heat play? This only seems to happen to mine on warm days, with a warm engine, after the car has sat for 5-10 minutes. And I don't get a "click," just gurgling from the fuel pump.
dcb
Old 05-26-2009, 03:31 PM
immortal_suby's Avatar
Thread Killah
Thanks for the info, the picture explains it clearly.
I need to do this also.
Locker Link
2015 BRZ Limited 6MT
Old 05-26-2009, 04:41 PM
K_Dub's Avatar
K_Dub K_Dub is offline
Headin' for the hills
+1, On the to do list
'92 LS-L "Bandit" #362 formerly dark teal, repainted by prev owner
Mods: ECUTune 2v7f, Earthworm bushings, Pioneer DVD/Bluetooth phone, Infinity Reference all around, tint, 17" wheels, custom seat belt computer, velcro visor
Buying parts is like car payments. Someday she'll be all mine.
Old 05-26-2009, 05:25 PM
dcb
When the connections, all the switches, and solenoid heat up their resistance increases, this reduces the current flow. So it will happen more, when hot.
Old 05-26-2009, 05:28 PM
I pinched the picture from Keith.
Old 05-26-2009, 08:12 PM
A rise in temperature is exposing a fault, which is introducing resistance within the starting circuit switching, there being several points where this can occur.
A relay having less resistance and therefore drawing less current than the starter contactor solenoid, is not affected to the same extent. However it must be accepted that the fault remains and could deteriorate further, to an extent whereby the relay may not operate.
Old 05-26-2009, 08:18 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Here is a write up with photos;
http://svx-iw.com/svxiw/article/?article=196
Old 05-26-2009, 08:26 PM
dannmarr's Avatar
I work for my SVX
Here is another diagram and a photo of the installation.
#30 positive
#86 negative
#87 starter
#85 to wire that was removed from starter
