Old 04-29-2009, 05:09 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Steering shudder
A couple months ago I rebuilt my LF caliper. I then quickly threw my wheel back on and drove about 35miles away. About halfway to where I was going I had a horrible wobble coming from the wheel I just put on. So I finished driving to where I was going and back to my house. I then inspected the wheel and I turned the lugnuts off with my fingers. After fixing my mistake I tourqed the wheel back down and it drove straight. Now after that happened I have a shudder in the steering wheel when i'm driving straight, and it goes away a little in turns. It only really does it going about 45mph and above. Any thoughts appriciated.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 04-29-2009, 05:14 PM
Gamesy's Avatar
Gamesy Gamesy is offline
Re: Steering shudder
sounds like either an alignment is off or something might've warped. Did you check the wheel bearing?
Old 04-29-2009, 07:45 PM
The alignment seems fine, it doesn't pull to one side. I also checked to see if anything was broke and it all looked normal. I haven't checked the wheel bearing.
Seth
Past subies:
Other toys:
Old 04-29-2009, 10:07 PM
A car can steer straight and still need an alignment or have something out of whack.
Old 04-30-2009, 08:15 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Maybe you lost a balance weight on the rim. Check the wheel balance.
Old 04-30-2009, 04:01 PM
I have to get the car aligned next week so i'll post what I find.
Seth
Past subies:
Other toys:
Old 04-30-2009, 04:28 PM
paulmeisterpk's Avatar
paulmeisterpk paulmeisterpk is offline
Sconnie
Send a message via MSN to paulmeisterpk
That would be the first thing i'd have done.
Old 05-08-2009, 07:04 PM
I checked the rim today because I needed all new lugs and there was one tiny weight on there and the residue from the whole other strip on there as well so looks like i'm getting it rebalanced.
Seth
Past subies:
Other toys:
Old 05-09-2009, 10:12 AM
Loosing a wheel weight would do it.
