Old 04-19-2009, 08:54 AM
Blenderhead Blenderhead is offline
Stripping a donor car for a 5-speed swap, anything else I should grab?
I just finished grabbing what I think is everything I need for the 5-speed swap. I have a 93 impreza that I am using as a donor car. The car has to go back to the junkyard when I am done, but for the $350 I paid, I'm allowed to take anything I need to do the swap. As of right now, I have the trans with shifter, flywheel, clutch/brake pedal, rear diff, all 4 axles, driveshaft, and all the misc bolts and brackets I took off in the process of getting those pieces. Is there anything else I should grab before this car goes back to the junkyard?
MY TOYS
95 SVX
98 Lincoln MarkVIII LSC, 5-speed swap
91 Marcury Cougar, 393" stroker, completely insane!
89 Mercury Cougar XR7, supercharged V6/5-speed, one of 2209. Engine currently dead, replacement in garage being rebuilt.
80 Pontiac Firebird formula, 350TPI swapped in, car needs to be finished.
Old 04-19-2009, 09:32 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Re: Stripping a donor car for a 5-speed swap, anything else I should grab?
I think if I remember right you may have some issues with a 1.8 clutch set up (pressure plate actually as the disk is the same). You grabbed the starter right?
Old 04-19-2009, 09:48 AM
Yes, I grabbed the starter. I was planning on getting a new clutch when I install it anyway. Will I have to order one for a different car, or what?
MY TOYS
95 SVX
Old 04-19-2009, 01:07 PM
benebob's Avatar
Do a search of Imp 1.8s on here. If I remeber right the pressure plate is a little weak for long term success on an SVX.
Old 04-22-2009, 12:03 PM
Like I said, I plan on getting a new clutch anyway. As long as the flywheel is the same, I'll get the new clutch for another car. If the flywheel is not the same, I'll have to buy the correct one too. So with that in mind, what should I order a clutch for? And can I use this flywheel, or do I need something different?
MY TOYS
95 SVX
Old 04-22-2009, 12:37 PM
I have checked into it, and the AWD 1.8 uses the same clutch as the 2.2 AWD....now the FWD 1.8 does use a different clutch, and axles
Old 05-06-2009, 09:25 PM
jokethis89's Avatar
jokethis89 jokethis89 is offline
95 Laguna Blue 5 Speed
Send a message via AIM to jokethis89
My donor car was a 98 outback, but I also ended up using the brake master cylinder because the rod length was different. I know you said you had all the bolts too but don't forget the flywheel bolts, they are not easy to find. Probably the biggest hold up when I converted mine.
Old 05-06-2009, 09:45 PM
Well I didn't get the brake master cylinder, so hopefully everything will be alright with that. I did grab the flywheel bolts though, so I'm good to go there.
MY TOYS
95 SVX
