Old 02-06-2009, 02:54 PM
taylorbr's Avatar
taylorbr taylorbr is offline
Car dies shifting into reverse...
As the title says, my car dies intermittently when shifting from park into reverse. Are there any obvious causes for this? I'm going to get my battery checked today to make sure that it is OK and I know my alternator works. The car does fine just sitting there in park so my guess is that the transmission is the culprit (maybe it's too hard of a shift?).
'93 Legacy LS (will last longer than the cockroaches)
'94 SVX LSi
Old 02-06-2009, 03:10 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
Re: Car dies shifting into reverse...
check to see if your air filter is properly attached first. is there a check engine light on? does your power light blink when you start the car?
- John
Old 02-06-2009, 07:46 PM
taylorbr's Avatar
Battery is good, air filter is good, no CEL's. Power light flashes due to bad dropping resistor. I've had the engine die shifting into reverse with the dropping resistor being both good and bad though, so that's not the culprit.
'94 SVX LSi
Old 02-06-2009, 07:49 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Sounds like your losing line pressure when selecting gears.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 02-06-2009, 09:48 PM
newkid17's Avatar
newkid17 newkid17 is offline
Send a message via AIM to newkid17 Send a message via Yahoo to newkid17
i have this problem a couple months ago, i checked everything and come to find out my MAF wasnt connected all the way in...
