Old 01-13-2009, 07:31 AM
SVX JAZZ's Avatar
SVX JAZZ SVX JAZZ is offline
Tired
Installed new radio and now no shifter light
I recently installed a new radio and now I don't have illumination for my console shifter light. There are three "dimmer" wires so I don't know if me not connecting them had any affect on the shifter light. Or... Did my light simply burn out and it is a coincidence.
P.S. Thanks to David Carter for putting together the radio instal website. Amazing...
Paul
1992 LSl (Black Mica)
1965 Mustang G.T. Fastback
1990 Mustang G.T. Convertible
1986 1/2 Nissan 4x4
2004 Vovlo XC70 (wife's)
Wonderful Wife
Wonderful Son
2 Cats
Incredibly blessed!
Old 01-13-2009, 08:33 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Re: Installed new radio and now no shifter light
my guess is that you snagged a line during the install....you're going to want to get back in there and see what's up...it's very possible you nicked a supply line that's now grounded out.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 01-13-2009, 09:33 AM
IceBlade's Avatar
IceBlade IceBlade is offline
Send a message via MSN to IceBlade
Same thing happened to me. Just pull it out and make sure everything's connected. Or you can be like me and say screw that, and leave it.
Old 01-13-2009, 11:32 AM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
I think if a wire is shorted, there would be more illumination lights out around the dash.
Since it's enough of a pain to slide the radio cage in and out of the dash, I'd start with the shifter bulb — check whether you're still getting voltage there and whether that bulb is burned out.
Did you insulate the unused dimmer wires behind the radio?
David C.
Old 01-15-2009, 06:19 AM
SVX JAZZ's Avatar
Tired
I did insulate the wires I didn't use. Its not a huge issue to me but I like everything to work. Yes, the radio cage is a pain to get out and I don't plan on doing that for a while!
