Old 07-02-2002, 10:22 AM
petesvx2's Avatar
petesvx2 petesvx2 is offline
Question cruise control problems
hey everybody...i own a '92 pearl/black svx and i have a question. the car is fully loaded with all the goodies and i do have cruise control and the switch lights up when i push it...nothing happens with the speed though, it just plain old doesnt work. i was wondering if anyone has any suggestions. help please!
-pete
Old 07-02-2002, 10:28 AM
Never2phat Never2phat is offline
Most likely: http://www.subaru-svx.net/photos/fil...2phat/2602.jpg
Welcome to the club by the way
B.C.
Old 07-02-2002, 12:06 PM
Mr. Pockets's Avatar
Moderator
Pete, I don't mean to offend, but I do like to be specific. You mentioned that the light on the 'cruise' button comes on. But are you using the little paddle on the steering wheel to set your target speed?
Again, I just want to make sure.
Welcome to the club.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 07-02-2002, 02:31 PM
A good point!!! I didn't even think about that - good job I still like my answer more though
B.C
Old 07-03-2002, 11:38 AM
petesvx2's Avatar
yes i am using the paddle to set the speed
thanks for the concern and yes i have tried using the paddle and no luck...what to do?
Old 07-03-2002, 11:47 AM
Boone
Hmm..
It wasn't the vacume hose
Old 07-03-2002, 11:59 AM
petesvx2's Avatar
maybe
boone- thats what i was thinking i took a look and there is a thin black hose snapped off right at the point where it meets with a black cylinder. is this what you are talking about? if so how much to replace it and is it easy enough to do myself?
Old 07-03-2002, 12:07 PM
Boone
Sure, you can replace most of the vacume hoses. If they are that brittle you will have more problems than cruise control. You just have to find out where they go.
Old 07-03-2002, 12:14 PM
petesvx2's Avatar
the hose i found was broken near the firewall and it goes and connects to another piece of hardware but not visible, more underneath if you were to look under the hood straight at the engine
Old 07-03-2002, 02:54 PM
Question Confused.......Where?
I'm confused(no coments from the peanut gallery ). What part is the hose not connected to? Is the hose not connected to the little horizontal black cyclinder(little plastic tube sticks out a centimeter or two from the right side). Or is the hose not connected at the other end. The other end does not go through the firewall but through a 1.5 inch by 1.5 inch square hole below the left of the engine fuse box. If it is not connected to the black cylinder simply slip it back on There is no need to relpace it if it has slipped off. There is no clamp to hold it on so it just falls off sometimes.
B.C.
P.S. If the hose has "snapped" off toward the cylinder end I would simply clip the rough end and see if it will still reach to be slipped back on. If you pop the hose out of the top guide clip(there are two lil clips that direct where the hose is going) you will have a good amount of extra hose to play with.
Old 07-03-2002, 03:09 PM
svx_commuter's Avatar
If the plastic "nipple" has broken off, JB weld can be used to reattach.
