View Poll Results: Have you changed your wiper setting to "winter" yet?
Of course! When I changed over to my snow tires and checked my anti-freeze! 9 27.27%
I'll do it right after the first time I have to chip the ice off my wipers to free them up. 12 36.36%
I leave them on "winter" setting all year long to prolong the life of the wiper blades. 9 27.27%
There's a SWITCH????!!! COOL!!!!! (Where is it?) 3 9.09%
Voters: 33. You may not vote on this poll
Old 11-18-2008, 09:49 AM
green_eyed_lady's Avatar
green_eyed_lady green_eyed_lady is offline
Winter Wiper Setting
For those who don't know, there is a rocker switch located under the driver's side dash to the left of the steering wheel which changes the windshield wipers between "summer" and "winter" settings. This controls where the wipers "park" when you shut them off. On "summer" setting, they park lower, against the "bumper" below the windshield itself, hiding them from sight under the hood. On the "winter" setting, they park higher, on the glass.
This is one of those things (like the telescoping steering column) that many owners don't find until they've had their SVX for a while.
Diana
1992 Liquid Silver LSL, >230K -- "Silver Bullet" // dimpled/slotted rotors, SS brakes lines, 5000K HID headlights // TRI-TONE paint
Old 11-18-2008, 10:02 AM
Re: Winter Wiper Setting
I try not to drive the SVX in the winter because of how much salt they use on the road with how much salt is already in the air down here But for the occasional donut run, I already switched mine over
Good thing I have good tires on teh Fonz!
Old 11-18-2008, 10:04 AM
JaySVX's Avatar
JaySVX JaySVX is offline
Mine are on winter year round, as I don't have the factory blades iwth the holders yet, and use cheap blades, so I don't want to have hte bent up more htan necessary. Once I get a set of factory blades it'll be a different story.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 11-18-2008, 10:16 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
I can't remember what I was doing when I found out that there were different settings for the blades. But when I found it, I remember thinking how odd it was to place it so far down there. Besides the odd placment, anyone wanna enlighten me on how much of a difference it makes if they are on or off? I've got the contouring blades.. The expensive ones...
Old 11-18-2008, 11:22 AM
If I spent more than 10.00 on blades (I know, I'm a cheapskate), I would probably leave them on winter setting. The first thing I notice when they start to wear is a streak right in the middle of the wiper path where the rubber has "warped" from the bumper and no longer makes good contact with the glass. The difference (on my car) is about 3" on the PS and 3-1/2 to 4" on the DS. Of course, if you're going to leave them on winter setting, you can adjust them down as low on the glass as they will go and just leave it that way. They will show above the hood at all times. If you adjust the summer setting so that they don't hit the bumpers. they will hit the A pillar, as I believe the "sweep pattern" is set by the winter setting (which is 3-4" higher.)
Anyone, feel free to correct me if I am mistaken about any of this.
Diana
Old 11-18-2008, 12:03 PM
B-Rad's Avatar
B-Rad B-Rad is offline
It's pronounced "Bee Rad."
I've left mine on the Winter setting since I bought the car 7 years ago, just because whenever I tried using it on Summer mode, the wipers would stop abruptly at the edge of the windshield whenver I used the Mist feature on the control stalk (pulling it towards yourself for one quick sweep). bugged the bejeebus outta me, so I kept it on Winter.
(Does Summer mode do this for everyone else too, or is there something wrong with my wiper motors / relay? [Not meant for a hi-jack, do not elaborate with technical posts ])
Ryan AKA B-Rad AKA The Swede
ShiuludeSVX's Avatar
I also switch them "up" whenever I wash the car, so I can clean them too.
Oh, they will hang out for you to clean and change the blades also.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 11-18-2008, 01:25 PM
Hondasucks's Avatar
Subaru Technician
My switch has no effect on where my wipers park, but I also have the problem described above, where if they are on the intermittent setting or if I use the "mist" function, they pause briefly at the top of the travel. I have OEM blades, but I don't have the bumper thing on the blade itself, perhaps I need to order specific SVX blades?
1986 VW Jetta
Old 11-18-2008, 02:03 PM
i never use the winter wiper setting. perhaps the most worthless feature of the svx.
Old 11-18-2008, 02:34 PM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
That is the motors setting themselves back to summer mode, its normal.
Hondasucks; your problem is probably that your summer/winter switch is set to summer and is unplugged.
Dustin
-Dustin
Old 11-18-2008, 02:42 PM
Sov13t's Avatar
Sov13t Sov13t is offline
Would be cool to wire it to the outside temperature sensor... so that the wipers adjust based on the predefined outside temperature ranges. For example 0 - 40 = Winter, 41-110 = Summer.
Heheh, just an idea.
Subaru SVX 94' Laguna Blue - 8.5 C/R Built Motor, 6spd
Old 11-18-2008, 02:58 PM
Freeman's Avatar
Unregistered User
What about 110+? Super Summer?
Old 11-18-2008, 03:54 PM
LetItSnow's Avatar
My 10th Subaru is a WRX
On any days where precipitation is taking its toll, I park them high, and it's for the same reason mentioned above - in what we're calling "summer mode", the wipers, on their final pass before parking, do that wonky thing at the top of their swing unless they're in what we're calling "winter mode".
I can't vote; there's no selection for "My car's setting changes with the sky."
Old 11-18-2008, 04:48 PM
Manarius's Avatar
Manarius Manarius is offline
I wish that the wipers didn't do that silly pause thing, but whatever. It makes my car cool.
I keep mine in summer until ice hits then I move them. I don't like how high they park in winter mode for times other than winter.
-Jason
-Obi Wan Kenobi
Old 11-18-2008, 05:43 PM
immortal_suby's Avatar
Thread Killah
I switch to winter when it rains/drizzles so that I can swipe them quick without the long slow return of the summer setting.
Locker Link
2015 BRZ Limited 6MT
