Old 09-21-2008, 11:50 AM
Old Fogey
Early vs Late Exhaust Differences?
I had occasion to be under both my '93 wreck, and my recently purchased '97, looking to correct an exhaust leak, and found curious differences in the exhaust(s). I've done a brief search on the subject with negligible results, so thought to ask.
It appears my '93 has the spring bolts at the front and rear of the 2-1 cat, using doughnut style gasketry, verified by my FSM, where my '97 has 4 nut/bolts at the front, using a metal/fiber gasket, and spring-bolts at the rear, using doughnut style. My question follows:
Looking at subaruparts.com diagram it appears there are also doughnut style seals (44184 No 1) fitted with the flat gasket (44184A No 2) , centering the two tubes exiting the flange at the front on the pass-throughs on the metal/fiber flat gasket . Is this correct? If so I guess I can see where my ultimate fix is, as they are missing on the '97.
Any help??
Glenn
Old 10-01-2008, 01:03 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
Re: Early vs Late Exhaust Differences?
your going to need to order new bolts and gaskets any way just see what the parts store hands you
- John
Old 10-01-2008, 04:24 PM
Old Fogey
Tried that at the dealer, and was finally assured my vin# required the spring-bolts,gasket and nothing else. Ended up at an exhaust shop, finding a torn hanger weld about 10" in front of the cat. Replaced piping and welded directly to the cat for the fix.
Glenn
