Old 08-21-2008, 05:19 PM
glaze148 glaze148 is offline
Question Rust Proofing
Just shipped my rust free 92 LSL Touring to the East.
How does one rust proof a car???
Thanks,
Steve
Old 08-21-2008, 05:32 PM
Mensaf's Avatar
Mensaf Mensaf is offline
What do you mean wrong SVX?
Re: Rust Proofing
Rust Bullet. 2 Layers.
Old 08-21-2008, 07:55 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: Rust Proofing
The underneath of the car already has good rust proofing. The things I would do is reroute the sunroof drain hoses past the rear wheel wells straight to the outside of the car on the ground. This helps prevent the common quarter panel rust. Another good spot for rust is along the lower door cladding. I would say run a piece of 3M moulding tape along the top of it. I think there should be one on there all ready but it's old. That's all I can think of.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 08-22-2008, 09:16 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Re: Rust Proofing
The major problem with the northern and Northeastern cars is that owners do not wash them completely (including under the car) often enough during the winter with salty roads. This would greatly reduce much of the rust problem.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 08-22-2008, 04:14 PM
maxg765 maxg765 is offline
Re: Rust Proofing
Hello
Relocating the sunroof drains? Just wondering a little more about this. Looks like I too I will be using my SVX (97 Ebony)through the winter months. If it does happen I would like to take care of it as best I can. Is this hard to do? Is it reversible afterwards if one should want to return it to the factory setup?
Thanks
Max
Old 08-23-2008, 05:13 AM
Re: Rust Proofing
Thanks everyone. I'll look into all of the suggestions.
Steve
Old 08-23-2008, 09:53 AM
Mensaf's Avatar
Re: Rust Proofing
Lee
Totally agree with this. People laugh at me when I was/wax my car before a snowstorm. Guess who has no rust after winter
Old 08-23-2008, 08:04 PM
Re: Rust Proofing
All you'll be doing is adding more hose to the existing ine to make it long enough to drip water to the ground instead of pooling in the fenderwell.
Originally Posted by maxg765 View Post
Hello
Thanks
Max
Seth
Past subies:
Other toys:
Old 08-24-2008, 02:58 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Re: Rust Proofing
1. Don't put on aftermarket rustproofing crap as Subarus rust from the inside out so most of the snake oils they sell simply keeps water from getting out.
2. Wash your car very often, in snow don't park in a heated garage.
3. Add a little kerosene to your wash water as it'll form a nice little oil barrier on the metal.
4. Don't fix under body oil leaks.
Old 08-25-2008, 08:05 AM
SVX_MY_BABY's Avatar
Re: Rust Proofing
Hate to disagree with your opening statement benebob. Most rust proofings do as you say and trap the water and salt against the metal, but not all. That is a problem with wax & tar/plastic coatings. When the coating is scraped or cracks it allows moisture in which is then trapped.
"Rust Check" brand and "Krown" brand work differently by staying liquid and displacing the moisture. They are the only ones here endorsed by the Canadian Automobile Association. The product is hard on some of the soft rubber gaskets which will swell after many years, but they are replaceable. My 92 has been done annually & is rust free. It's an annual application & costs about $100.00. Good insurance.
As an aside Honda Motors has their world corrosion test center here because of our "known" destruction by corrosion of cars.
Old 08-25-2008, 09:24 AM
benebob's Avatar
Re: Rust Proofing
Personally I wouldn't trust a product that is sold only at Kmarts in all of PA, nor would I trust it just because they gave money to the CAA. My guess is that rust check is nothing more than a kerosene based product which for $100 buys you quite a bit of kero even at today's prices. If it was as good as you say then it would have a huge dealer network.
Now if they want to provide a 100% warranty for the appearance of even a niggling of surface rust then sure I'd pay 100% for their snake oil. If not buy yourself a gallon of kero and use a method that's been around the classic community for 75 years.
Good luck with your product but proper mant. goes much further than any spray on rust crap ever will. Maybe you're just rust free because you, well, take care of your baby!
Old 08-25-2008, 10:09 AM
SVXyGirl's Avatar
SVXyGirl SVXyGirl is offline
Re: Rust Proofing
+1
Rebecca
06 Suzuki Boulevard M50 7k
Past SVXs:
96 SVX Bourdeaux LSi (Sold)
Old 08-25-2008, 10:22 AM
Re: Rust Proofing
There is a huge dealer network in Canada for both Krown and Rust Check which also has head office run outlets. I'm talking dealer applied product, not cans of spray bomb. They also offer a repair warranty to the value of the car if has been done annually from the time it was put into service, for what thats worth.
They are not petroleum product.
That said, for me, it's my experience over time and the fact that if you speak with body shops and mechanics in these parts they are virtually all in agreement that vehicles treated with these two products have much better body and undercarriage integrity than those that aren't.
It is also interesting to note that they will not treat some cars (e.g. newer Saabs) or only partially spray them, as they work with the car manufactures to determine correct application methods for each model which will not damage the vehicle.
( In the case of Saab their electricals are routed in such a way that insertion of the spray wands may cause damage.)
Old 08-26-2008, 08:59 AM
zavikan zavikan is offline
Re: Rust Proofing
hmmm up in the north country of NH, Alot of the shops spray linseed oil all over the underside. Sounds like the kero approach, but possibly longer lasting?
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN!
Old 08-26-2008, 05:57 PM
benebob's Avatar
Re: Rust Proofing
Considering I took this from their website and nearly all mineral oils are petroleum based I would tend to disagree with that. I'm not knocking it at all btw just offering a cheaper similar solution that is time tested.
"The main ingredients in Rust Check products are highly refined (Purified) mineral oils. These oils are similar to those used in personal care products such as medicinal mineral oils, baby oils, and cosmetics" Rust check website in the enviromental section!
