Help! My Brakes Are Gone
I HAD A LEFT FRONT BRAKE HOSE BREAK SOO I ORDERED THE NEW ONE AND REPLACED IT I BLED THE LINE AND WHEN I TOOK IT FOR A DRIVE I STILL HAD ABOUT AS MUCH PEDAL AS I DID WHEN THE LINE WAS BROKE SO I JACKED IT BACK UP AND CHECKED THE FRONT RIGHT LINE FOR AIR AND IT SEEMED FINE SO, THEN THE BRAKE LIGHT CAME ON, SO I ATTEMPTED TO PULL OUT OF MY CAR PORT AND ALMOST PLOWED INTO MY WIFE'S BRAND NEW CAR BECAUSE NOW I HAVE NO BRAKES AT ALL.
cOULD ANYNE TELL ME WHAT I DID WRONG OR WHAT TO CHECK. THAKS GUYS I APPREICIATE IT. |
Turn caps lock off, that might help.
-Dustin 1992 Ebony LS-L w/191k miles Mods: a few ![]() ![]() ![]() 1995 Brilliant Red L/AWD w/154k miles Mods: Stebro catback exhaust, K&N drop in filter, ECUtune ST1v5, 4.44, lots of JDM goodies 1992 Pearly LS-L w/154k miles Sold ![]() 2008 DGM Legacy spec.B w/245k miles Mods: Cryotune Stage3, VF52, bushings galore, STi pink springs, Bilstein HDs My Locker The only man alive who drives three "Subu SVS's".......according to my insurance company |
But seriously.....
Did you check the brake fluid reservoir? Try bleeding the entire system. The factory specified way to bleed our brakes is starting with the Rear (Primary) port on the ABS unit (closest to the firewall), then the Front (Secondary) port. After that it is: Front Passenger wheel, Rear Driver wheel, Front Driver wheel, Rear Passenger wheel.
-Dustin 1992 Ebony LS-L w/191k miles Mods: a few ![]() ![]() ![]() 1995 Brilliant Red L/AWD w/154k miles Mods: Stebro catback exhaust, K&N drop in filter, ECUtune ST1v5, 4.44, lots of JDM goodies 1992 Pearly LS-L w/154k miles Sold ![]() 2008 DGM Legacy spec.B w/245k miles Mods: Cryotune Stage3, VF52, bushings galore, STi pink springs, Bilstein HDs My Locker The only man alive who drives three "Subu SVS's".......according to my insurance company Last edited by odepaj; 06-05-2008 at 02:34 PM. |
![]() Bleeding is good. Don't recycle the fluid you get from the bleed tho. Gotta check the Resevoir after the bleed to make sure it's not all gone. Really low would do it too, because the rubber membrane is now creating a vacuum instead of a push.
The Worm ![]() _______________ June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod" Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012 '05 Infinity G35 Coupe. No Mods, 33K Miles |
