Old 05-31-2008, 01:15 PM
BeneathNorthernSkys's Avatar
BeneathNorthernSkys BeneathNorthernSkys is offline
Work, Sleep, SVX, Repeat
Transmission Fluid
What type of fluid is best to put in once you've rebuilt your tranny? I read that 7.4 quarts is the ammount that is needed too, making sure this is correct as well. I just want to put the best stuff possibly in it.
Jordan
1992 SVX LS-L 126,xxx Sold
1990 Non-Turbo 300zx 127,xxx
1991 Non-Turbo MR2 214,xxx, replaced engine at 190,xxx
Watch your thoughts, for they become words.
Watch your words, for they become actions.
Watch your actions, for they become habits.
Watch your habits, for they become character.
Watch your character, for it becomes your destiny...
Old 05-31-2008, 01:32 PM
A quality synthetic ATF like Mobil 1, Amsoil or Redline would be desirable. The 4EAT transmission and torque converter would take 12 quarts of fluid.
Where did you get the 7.4 qt. figure?
Old 05-31-2008, 08:27 PM
just looking through info I found on the web, idk, apparently someone is way off though, it would be the first time I would do it, so I guess I'm glad I asked
Jordan
Old 05-31-2008, 11:55 PM
lechnoid's Avatar
lechnoid lechnoid is offline
Tech & Almost Lawyer
I've used Redline in my RX-7s through the years and have had outstanding luck with it. Granted, those were all manuals, but it's still a quality product.
Old 06-01-2008, 11:04 AM
Maxo's Avatar
Maxo Maxo is offline
Don't over fill!
12qts may be too much, I'd go with more like 10 to start. You don't want to over fill. Over filling is much worse for a transmission than not putting enough in. When I rebuild my tranny, had the tq completely drained, I put in 11qts. I was a little worried about having overfilled it but it ended up being good.
I think if you just drain the tranny and let it sit for a few hours you need to put around 7qts back in.
Old 06-01-2008, 12:26 PM
Sir. Nate's Avatar
Sir. Nate Sir. Nate is offline
SVXtreme
the best method is to dump some in, measure, repeat
-Nate
'92 LS-L Pearlie
Old 06-01-2008, 07:58 PM
Wolfy's Avatar
Wolfy Wolfy is offline
Send a message via AIM to Wolfy
they have this stuff called "trickshift" in my advance auto near me. i swear by it! its a bit thinner but has the same heat disipation (cant spell lol) i swear when i changed my tranny fluid and pu trickshift in the shift time was a bit faster and it seemed smoother. also its got this funky blue color... lol
heres a link to it http://store.summitracing.com/egnsea...5&autoview=skuhttp://store.summitracing.com/egnsea...5&autoview=sku
Old 06-01-2008, 11:18 PM
kwren's Avatar
kwren kwren is offline
Dissipation
I miss the spelling on all words that have double letters all the time.
If it has a place for 2 double letters in the same word, I miss them both.
Old 06-02-2008, 01:44 AM
wow, seems like everyone has their own opinion on this, now to choose the right one.....hmmmm
Jordan
Old 06-02-2008, 01:35 PM
Wolfy's Avatar
Cool trick sift, trickshift, trick-shift....
TRICK SHIFT! lol
Old 06-02-2008, 04:52 PM
When you drain the transmission, you only get to remove the 7.5 quarts of oil that is in the gear box, the torque converter that holds the rest of the total 11 quarts.
If you are going to change to a Synthetic you need to drain the whole 11 quarts, or you will be mixing the two types of oil together, that is not good.
Old 06-02-2008, 09:55 PM
scottsubarus's Avatar
scottsubarus scottsubarus is offline
Scottsubarus
Any transmission that my company sells automatically comes with Mobil 1 transmission fluid where internal heat is an issue, and cause of premature failure. Not only will Mobil 1 handle the excessive heat better than dino oil, but will also lower internal tempreture.
Scott Shaeffer
Certified Transmission
Old 06-03-2008, 09:21 AM
kwren's Avatar
How...........
How do you get the oil out of the torque converter?
Keith
Old 06-03-2008, 09:59 AM
Scottsubarus
Keith.....you don't.
even if you were to remove it, it's almost impossible to drain if flipped over. It's never adviseable to drill a hole and attempt to re-weld as it wouldn't be balanced.
Old 06-03-2008, 12:31 PM
wait, so I'm not really sure what was in my car prior to the rebuild. I didn't even mess with the whole transmission, I just did the front differential, which brings up another question, what gear oil is required for the front diff? 90w?
Jordan
