Old 05-14-2008, 11:39 AM
black beast black beast is offline
Back Road Blazer
Send a message via AIM to black beast
Poly. bushings
Was there a group buy for a complete set of polyurithane bushings? My rubber ones are shot, but I want to get the poly ones, if they are offered.
-Chris
'94 ebony pearl, with orange "silicone" hoses, painted beauty cover, Tom's Intake, Dayles Cold air intake; with HKS mega suction foam air filter, 3in header back exhaust, STI ground wires, euro front fascia, euro front grill, reactive 17in wheels, Nitto Invo's, Drilled and slotted rotors, stainless break lines, Koni strut inserts, Drop springs, 5MT, shotshifter, Clutchmasters clutch, ACT prolite flywheel, EL Glow gauges, The ECUTune stage 2. To Do: Cams, port and polish, etc.
Old 05-14-2008, 09:10 PM
It's Just Eric's Avatar
Missing in action
Yes. a search yields many results
There are part numbers for compatable bushings that can be found at most parts stores, or you can contact Earthworm about his custom run of poly bushings
R.I.P Cool Signature.
Old 05-14-2008, 09:36 PM
I thought the control arm bushing run failed, didn't it?
What bushings are we talking about anyway, swaybar, diff, other???
blk 92' LSL w/ average mods
Old 05-14-2008, 10:34 PM
Hondasucks's Avatar
Subaru Technician
I need diff bushings (the ones in the cross bar, above the rear diff) as both mine are torn and my car makes a nice "THUNK" if you turn while backing up.
1986 VW Jetta
Old 05-14-2008, 10:39 PM
Missing in action
Bush, bushes, bushings....
Um, Right. I was originally mentioning swaybar bushings.
Mr. Sucks, if your sure the thunking is from the rear diff bushings, might I suggest the solid polyurethane bushings offered by both tom's? Ive had a set in my black car for a while, and I KNOW they arent going anywhere soon...money well spent
Old 05-14-2008, 10:42 PM
How much and how hard to do?
I am sure mine are toast too. I replaced motor mounts, diff mount and the horrid noises just get worse. I am thinking carrier bearing support is bad too.
Old 05-15-2008, 05:09 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
I got a set from YT, and in the process of replacing them, found that the center was all but gone. The center plunked right out into my buddy's hand!
Old 05-15-2008, 09:15 AM
energy suspension bushings, got them at Checker auto. need slight mod to fit fronts, there's a how-to on the board somewhere.
diff bushings, made them with 3m window weld, work perfect, easy to do better than OEM.
