Old 04-25-2008, 11:27 PM
fishtail fishtail is offline
Smile U Joint
Anybody ever change u-joints in the driveline? What has to happen to get the clips out? Does anyone know? Please help, thanks Fishtail.
Old 04-26-2008, 02:42 PM
well, i had it done only cause i didn't have acess to a press at the time. the OEM ones are staked in so when you get them out you have to grind out the stake marks. there are no c-clips on the originals.
rockford auto sells the replacement ones(with c-clips) but they have a grease zerk on them so you can grease the new ones, cool in concept but i think it threw the balance off cause over 45mph my car turned into a giant vibrating cell phone.
the guy doing the install said it was from play in the middle CV joint not anything he did, even though it started as i was driving away from his shop. who knows, could be but hard to diagnose. since then i took that one out and used a drive line from a later year( one with 3 u-joints instead of 2 u-joints and a CV) and the vibration is gone.
there are a few others on the site that have done it with sucess, but i'm not one of them. i may pull the ones from my rebuild shaft and put them in the one i am currently using, but not till it's absolutely nec.
