Old 03-28-2008, 11:14 AM
roadrosen roadrosen is offline
power steering leak
most common source? o ring? res? lines? any thoughts?
92 svx-L 138k
Old 03-28-2008, 01:31 PM
do you see red puddles on top of engine block behind P.S. pump? if so, possible o-ring failure. if drips are coming from lower crossmember look at the hoses on passenger side back under motor, this is where mine failed, i bought a piece of p.s. hose from some other car and cut it to fit since ours aren't locally avalible.
Old 03-28-2008, 01:35 PM
steering fluid lean
thanks lilbrudder, it seems to be low and on pass side. sounds like a hose, although i can smell some of it burning so maybe on engine block. i shall investigate further this weekend. thanks again.
Old 03-28-2008, 01:41 PM
There are two hoses that can leak.
High pressure - has metal pipe fittings on the end - you can buy a new one $$$$ or take the leaking one off and get it rebuilt at a shop that rebuilds hydraulic hoses.
Low pressure - has hose clamps on the end - you can buy 3/8" ATF line from your local autoparts store. They sell it by the foot.
Old 03-28-2008, 01:48 PM
^^^yup, that burning is the ps fluid dripping on your exhaust, pretty common, but get it fixed, my bros was dripping for like 6 months when it gave way almost catching the car on fire.
Old 03-28-2008, 05:37 PM
If the hose doesn't fix it, check the O-ring. That is in the How-To Documents and is an easy fix. It is a very common problem.
Old 03-28-2008, 05:58 PM
vrkSVX vrkSVX is offline
1992 Pearlie original owner
PS fluid????? I thought we were supposed to use ATF in the power steering.
'92 Pearlie-bought new
'10 Forester - burgandy
Old 03-28-2008, 08:12 PM
kwren's Avatar
kwren kwren is offline
Funny..................
one..................ATF is our Power steering fluid
Old 03-28-2008, 10:11 PM
exactly.
Old 03-30-2008, 09:49 PM
JLHollowX13's Avatar
JLHollowX13 JLHollowX13 is offline
Send a message via AIM to JLHollowX13
my power steering hose was leaking (the high pressure one) bought a new one from subaruparts, slapped it on pretty easily, no more dripping on exhaust!!! although im still losing a little fluid, maybe the oring, and i still smell slight burning, probably the exhaust burning off the last of the fluid. i would definitely check the high pressure hose, that seems to be a trouble one. if you can hear sizzling after a long drive and some sharp turns, thats probably it.
