Old 03-03-2008, 03:24 PM
CorSVXette's Avatar
Classic SVX
Alarm
Ok all you electrical gurus out there. Riddle me this: I have the OEM alarm system in my car. Why is it that I have to wait till the interior light goes off if I want to set my alarm with the key fob while others have told me that they can set their alarm as soon as they close the doors? I must wait for the interior light to go off ( about 30 secs.)
Paul
1969 Corvette
1995 Corolla
2003 Highlander
Old 03-03-2008, 03:38 PM
Paul, this has riddled me for a little while... There may be something outside of just the alarm module that you may need for the alarm to work in the L model properly... Let me look into this a little further
Old 03-03-2008, 03:49 PM
just looked at the schematics and really the only thing you do not have is a selt-belt controller. Now I wonder if the controller is needed for a security system that came out of a car with automatic belts???
Old 03-03-2008, 04:18 PM
Sir. Nate's Avatar
Sir. Nate Sir. Nate is offline
SVXtreme
just curious... where is the alarm module located? I've been looking for it for a while.
-Nate
'92 LS-L Pearlie
Old 03-03-2008, 04:23 PM
It could be that the alarm uses interior light voltage as a trigger signal, in which case it may be necessary for this to be deenergised before the alarm can be set. The alarm setting could well be is tied in with the timer module, which also controls the interior lights.
Refer Tom's post. Can you provide information as to the models which have the delay?
Old 03-03-2008, 04:33 PM
Trevor, he has a 94 L model which was not fitted with a factory alarm. A factory module was fitted and remotes programmed for his car.
Looking, the only shared power source the alarm has with the interior light circuit is for the tail lamps, which flash when the alarm is engaged or disabled. This does not look to be related to the interior light timer. I think it may just be a coincidence that the alarmed is timed out with the interior lights. Maybe there is a timer elsewhere that takes the same time to disengage causing the alarm to be inoperative until its deactivation?
Old 03-04-2008, 05:29 AM
CorSVXette's Avatar
Classic SVX
Originally Posted by TomsSVX View Post
Trevor, he has a 95 L model which was not fitted with a factory alarm. A factory module was fitted and remotes programmed for his car.
Corrected it Tom. I have a 95. And Sir Nate. It depends on the year. I don't know when they switched but the earlier years had the module behind the glove box while the later years (like my 95) have it located in a panel in the truck near the speakers. Ok Nate. I just saw your signature. You have a 92 so yours is located behind the glove box.
Paul
1969 Corvette
1995 Corolla
2003 Highlander
Old 03-04-2008, 06:43 AM
...I don't know when they switched but the earlier years had the module behind the glove box while the later years (like my 95) have it located in a panel in the truck near the speakers...
The deciding factor is whether or not there is a passenger side airbag.
Paul, to add to the confusion, have you tried it with the "Door Light" switch off?
Old 03-04-2008, 07:41 AM
CorSVXette's Avatar
Classic SVX
No Dave. I haven't. I will give it a try.
Paul
1969 Corvette
1995 Corolla
2003 Highlander
Old 03-04-2008, 11:09 AM
Sir. Nate's Avatar
SVXtreme
Thanks!
-Nate
'92 LS-L Pearlie
Old 03-04-2008, 02:35 PM
CorSVXette's Avatar
Classic SVX
OK Dave. I tried that but it still doesn't work because the "floor" lights still stay on.
Paul
1969 Corvette
1995 Corolla
2003 Highlander
Old 03-14-2008, 05:50 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Good Information
1995 POLO LSI 76K MILES SOLD
