Old 02-27-2008, 12:21 PM
dennyo dennyo is offline
Question external a/t filter
I noticed in the how-to section that the external filter is located on the framerail.I looked for mine and did not see one.Did subaru install one on the 96 lsi or is this aftermarket stuff.I'd like to put one in.Any help anyone?Thanks
Old 02-27-2008, 02:17 PM
Schralper's Avatar
Schralper Schralper is offline
Go here, order and install. Your tranny will thank you.
http://store.summitracing.com/partde...5&autoview=sku
WFO!
http://www.cardomain.com/id/Schralper
"You all laugh cuz I'm different
I laught cuz you're all the same."
Old 02-27-2008, 02:19 PM
I like the PermaCool filters which have the temp sensor fitting on them. I have put them on mine even if they have the small inline filter on them. I just like them better and you can get the replacements anywhere.
Old 02-27-2008, 03:29 PM
Schralper's Avatar
The Summit one has a fitting for a temp sender.
BTW it's just a permacool relabeled. Even comes w/ permacool papers.
An AC PF13 or alternate for shorty fits great.
WFO!
Old 02-27-2008, 04:10 PM
Thanks to all and thanks for the links.I've only put 2k on it since I got it.It's been garaged since nov. and I've got the fsm's memorized I've read them so many times this winter. I don't know the history of this car that well so I'm trying to be proactive and head off any problems.The car seems to run very well now but I'm sure it's not done with me yet
Old 02-28-2008, 06:04 AM
dcarrb dcarrb is offline
I believe the Subaru external ATF filters only came on the '92s (and '93s?), as these had a screen in the radiator ATF loop that was clogging and causing transmission failures. You can get a Legacy filter kit from Subaru for about ten bucks, complete with hose clamps and a length of hose, a protective rubber sheath (even a length of grounding wire), but you'll need to find an SVX-specific mount from a junkyard or e-Bay.
dcb
Old 02-29-2008, 04:04 PM
Octanerush Octanerush is offline
dcb
i bought a legacy filter kit from subaru (in canada) cost me 30$ came complete with everything u said and a mounting bracket too
