Power steering hose
My power steering hose recently sprang a leak, and it's now progressed to two leaks and is losing fluid pretty rapidly. I need a new leak free hose. Anyone got an extra to sell? Also are they available at subaru dealerships or online anywhere?
94 Emerald LS w/ awd 4.44 swap 199xxx daily driver Stage 2 ECUTune chip, 370cc injectors, ECUTune valve body and TCU, solid rubber motor mounts from a forester, outlaw phenolic spacers, COBBTuning lightweight blue crank pulley, Bontragerworks 22mm rear sway bar & endlinks, StrongFlex poly front sway bar bushings, Powergrid adjustable front sway bar endlinks, 17" MOMO CORSE RPM wheels w/ Toyo Proxes4 225/45, drilled/slotted rotors f/r, stainless lines, ceramic pads, Blue silicone radiator hoses, power mode switch, gold jdm hood badge, 20% tint all around, Hella optilux xtreme yellow fog bulbs parts waiting to go on car: the rest of the strongflex polyurethane suspension bushing set |
Is it the high pressure hose? The HP has the metal fittings on the end? The low pressure lines attach with hose clamps.
The HP can be rebuilt for $30-$40 at a local shop that rebuilds hydraulic hoses. A new one from Subaru is at least twice that...
its the larger diameter rubber or silicone im not sure which one that runs parallel to the block. it has a metal fitting at the end where it connects to the metal tube leading to the steering fluid reservoir.
Yeah, that's the HP. If you can go without the car for a couple of days, I suggest removing it and getting it rebuilt. If you're going to try a used one, make sure you get the right type. 92-9? has a metal tube that runs the length of the block and only uses the hose to drop down to the rack. 9?-97 runs the hose the full length like yours.
Just as Hocrest said take your old one out, take it to a hydro shop. Any large town should have one and by the next day you should have a new one made. They'll need your old one for sizing and reusing the fittings. Most will even give you a choice of hoses and colors.
I just replaced both hoses on my 92 w/ hp rubber and stock clamps.
Schucks had the hose, I used transmission cooler hose and just cut to length. 1 from pump to cooler behind a/c cond. and the short 1 from there to hardline next to block.
WFO! http://www.cardomain.com/id/Schralper "You all laugh cuz I'm different I laught cuz you're all the same." |
