Driving in "3" affect steering?
I read a lot threads about driving around town in 3rd gear so I thought I would try it. All of a sudden I noticed my steering was getting hard to turn. Like when coming out of a left/right turn, where the steering would almost automatically straighten out, I had to forcibly turn the wheel to straighten it out. Well I decided to try and go back to driving around in "D" today and it seemed to be working fine now. Is it a coincidence or does driving around in 3rd affect the steering?
Paul ![]() 1969 Corvette ![]() 1995 SVX L Safety Option Package, HID's & Awsome Braking (Svxfilies/TomsSVX), JDM Clear Corners, JDM Boxer Engine cover, Transmission Cooler, AND NOW JDM FOLDING MIRRORS! ![]() 1995 Corolla ![]() 2003 Highlander ![]() |
I've never noticed that. I'm guessing it's a coincidence. Have you checked your steering fluid?
Yea. Just did. It needed a little so I topped it off. I will try again in a couple of days to drive around in 3rd to see if it happens again.
There are two types of steering, rev sensitive and speed sensitive. The more expensive type is the speed sensitive. It is electronic. It takes a signal from one of the speed sensors, and using this as a yardstick it reduces steering assistance the faster you go. Yours being the fwd 95 car I think it likely you have the rev sensitive type, the cheaper model, but maybe some of the US guys can confirm. You ought to check out that your steering is mechanically OK. Run some tests on it when parked with the engine running. Check that the steering is easy to turn left or right with the engine running. Look out for tightness either side. This might indicate that one of your rack boots had punctured and you had a dry spot. If you notice this then get it looked at, a new rubber boot is cheaper than a failed rack. Also when doing this don't hold the steering on hard lock, either side, with the engine running. It's bad practice, and you could actually blow a pipe. Joe ![]()
I would guess a coincidence as well. My thought was the PS was a little low. Let us know what you find.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() |
i believe all LS-i models had the electronic spped sensative steering
Seth 94' Barcelona Red w/ Tricoat black 2-tone AWD Ls -Sold Mods:AWD conversion/4.44 swap by Budfreak, Custom red interior lights, Custom Satin black dash, Power mode switch, Cold air intake, Permecool tranny filter,Sony xplode 10" sub, Sony xplode 1000w amp, Blitz in-line driver, DDM Tuning 6000k HID's, New paint job/body work by me, 97' Grill, QC shift kit, 17'' MB Motoring rims, 15&20 min mod, front & rear urethane swaybar bushings, Custom fiberglass sub box, Custom red led a/c control unit, perrin lightweight crank pulley, Black wrinkle finish powdercoated intake manifold w/ clear hoses , 02' outback heated/power black leather seats Soon to come:Fiberglass hood, upholster ALL suede to black leather Past subies: 92' Pearl White/black top LS-L-SOLD 96' Legacy Outback-TOTALED 99' Legacy Outback Limited 30th anniversary edition-TOTALED 98' Forester L -Totaled Other toys: 99' Forester S -WRX brake upgrade, soon an 04 wrx motor swap 06' B9 Tribeca-Stock 1982' Yamaha xj650 Maxim Mods: work in progress Last edited by redlightningsvx; 12-28-2007 at 05:12 PM. |
Mine is a FWD and my Rack and Pinion is leaking. I am not sure I keep an eye on my fluids and also my engine needs a reseal. I don't notice a change in steering. I am about to go out and I will check this question out for you.
1994 SVX L - FWD Barcelona Red 190K miles ~ SOLD 1994 SVX LS - 5spd AWD Emerald Green 202k miles PWR Radiator, HID 5000k, New paint job with issues, 17" STI BBS wheels, converted to 5spd AWD from FWD. Purchased from SVXyGirl 2/20/09 -- Undergoing complete rebuild 1993 Justy 4wd 5door- Teal of sorts , beater. 2008 OBXT Newport Pearl 65k miles |
![]() ![]() There is a Seattle dealer from Subaru called Joe Spitz who has compiled a marvelous page showing options and years. According to him, your L [and the Ls]has the cheaper engine rev related power steering, while the top of the range Lsi has the road speed sensitive type for '95 See the '95 list here: http://www.cars101.com/subaru_svx.html Joe ![]()
He called your SVX Cheap!
That speed sensitive steering thing is kind of nifty. It makes it so at high speeds the car is "harder" to turn (to make it harder for you to screw up I guess?). This usually isn't the case with most cars because at higher speeds, higher revs means easier steering. It's fairly noticeable on my SVX.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount ( ![]() silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear ![]() (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
Hey, I'm walking on eggshells here!!
![]() Well, just to set the record straight, rev sensitive steering must have been a a luxury item this side of the Pond. Over here, we could not get that option for love nor money. ![]() ![]() Joe
Update
Well. I guess it was just a coincidence because it seems to still be happening. It seems to get a little easier to steer after driving around for a while, but still a little tight. I have not had a chance to re-check my fluid level since the last time i topped it off. Any ideas?. Tom(yt) if you are reading this, it looks like we may have another thing on my list for you to fix
