new Koni/GC DIY option
Hey Folks,
I've been looking for how to make the Koni/GC option as inexpensive as possible for people. For those who have the tools and basic skills to do a DIY Koni/GC setup, it seems to me that the biggest roadblock is having the car on jackstands while you disassemble and prep your own strut bodies. This can take as long as a week if the strut bodies are cleaned and painted. For you DIY folks, what I have decided to do is offer prepared strut bodies that are setup for the Koni/GC combo. If you buy Koni inserts and GC springs from me, then I can sell you a set of prepared struts bodies at my cost for $150. The strut bodies will be: - cleaned, beadblasted - cut and drilled for Koni inserts - welded for GC springs - primed and painted in the basic color of your choice with rust resistant paint This leaves you with the basic assembly tasks. I'll need your old struts for the next customer, so there is also a $300 core charge that will be refunded when you return your used struts to me. PM me if you'd like a set.
does this go for those of us that bought the koni/gc setup from you and havent gotten around to installing it yet? Im looking at doing it in May so time is not a big deal.
[SIGPIC][/SIGPIC] STi BBS wheels,legacy gt 4.44, 3" catback exhaust, Stance GR+ 7k/5k, QS Teflon adjustable endlinks, Hankook EVO 245/40/17, 95-LS escaine seats, GC8 V7 steering wheel, JDM clear corners, small car clear lenses, Alcyone badge, JDM rear taillight, 97 grille, stevesby bumper, PWR radiator, Perrin Crank pulley, Urethane Swaybar bushings, urethane diff bushings, DDM 6k 55watt lows and 4500k 35watt fog lights; $15/15min mod, Motorsport whs 22mm rear swaybar, QC shift kit, ToMyx intake, z32 aluminum calipers 13" rotors, nitrous express proton + wet kit. |
So what would the total pirce be for the koni's, gc's and the prepared strut bodies run?
2005 Legacy GT 2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles My WRX's Cardomain Page |
$1210 + shipping + $300 refundable core charge.
Sure. :-)
where were you when i needed you 4 years ago??? j/k...learned alot in the process. |
