Old 10-13-2010, 03:18 PM
Re: STI Suspension Swap Project
Why would that be a concern? The studs on the struts are barely structural (they're tiny little M6 or M8 bolts) and all the load is upwards. The top mount of the strut is a circular aluminum plate that distributes the load into the strut tower. All the studs do is keep the strut where it is.
Old 10-28-2010, 08:39 PM
TADA!!! 50% done. I only have the fronts installed at the moment, not enough time to get to the rear.
Before and after:
The drill plate I made to locate the new holes in the shock tower:
Camber plates!!! And pillow balls!
And voila, installed:
WOOO!!! I'm happy. I still have to install the rears, so I haven't yet felt the full effect, but so far this is awesome. Of all the coilover-equipped cars I've ridden in this one is by far the best. The ride is firm but not jarring and there's zero "bouncy-ness". There's minimal body lean when cornering. Specs on this system is 8kg/mm front and 6kg rear, or ~450lbs front/335 rear. If I try to bounce the front end of the car by hand... Nothing happens.
There's no rubbing, no odd clunking... And LOTS of height adjustment left. I could drop the car another 2-2.5 inches if I wanted to. Kind of ridiculous actually.
Now, the installation. If you have an aversion to grinders, drilling holes in your car, and making a set of coilovers non-resellable, this modification in not for you. Here's what I had to do:
1. Drill 2 holes in each shock tower
2. The Stance camber plate is a circle. I had to grind the sides down in 2 places (rear and outside) where it didn't fit inside the shock tower. The SVX top mounts are very triangular and the shock tower doesn't fit much more than them.
3. Grinding the knuckles heavily. The section the strut attaches to is a few mm thinner on the WRX. I took the knuckles right out of the car to do this, it would have been almost impossible to do on the car.
3. Oval the holes of the coilover lower mount. The two bolts on the SVX are more widely spaced than the WRX.
This took me an entire afternoon to install these (~7 hours) with the car on a hoist and air tools. A fair amount of it was the grind-test-grind-test-grind process, and a good hour was lost getting the two ABS sensors out of the knuckle. This job is not for someone who has only done oil changes. If you're not comfortable with fabrication work and custom modifications just get someone to build you a Koni/GC system.
Old 10-28-2010, 08:58 PM
Nevin's Avatar
Nevin Nevin is offline
Lookin' good! What are the springrates on these units?
I would't be afraid of doing any of the things you had to do! haha
Jesus is the remedy
2015 Expedition EL Ecoboost
Old 10-28-2010, 09:03 PM
8kg/mm front and 6kg/mm rear (about 450 lbs front/335 rear).
Old 10-28-2010, 09:05 PM
Nevin's Avatar
Gotcha!
Sorry if you said that before and I missed it.
Jesus is the remedy
Old 11-03-2010, 06:37 PM
Installation complete!!!!
Decided to change it up a bit and modify the camber plate instead of the car, since only one hole had to be moved. Press out stud, drill 5/16" hole, press in stud, done.
Took the rear knuckles off, ground them down, bolted everything together aaaannnnd:
When the car is in the air and the wheels are already at stock ride height you know you're in for something interesting.
On the ground:
This thing is LOW. The picture doesn't really convey just how close to the ground it sits. I can't get my baby finger between the front tire and the fender. It feels very strange walking up to the car now, and even weirder when the hood's open. I'm very accustomed to having the engine at a certain height, and now that it's 2-3" below that... Weird. I also tagged my exhaust on a small speed bump on the way home. The insanity begins!!!
The trunk is still full of tools and parts, so I haven't been able to give it a good drive to figure the handling out yet. Tomorrow!
Old 11-03-2010, 08:25 PM
StatGSR StatGSR is offline
Send a message via AIM to StatGSR
^ lol you have a baby finger?
besides that, looking good!!!
94 Acura Integra GSR
97 Legacy Brighton - EG33 Swap still in progress
03 Silverado 2500 - Duramax
Old 11-03-2010, 08:56 PM
Good work, Chris, but damn that's LOW!
Old 11-04-2010, 08:33 AM
Ricter Ricter is offline
Wow. I'm in love with the new ride height.
Have you reattached the front sway bar endlinks yet? You referenced how you might do it in the first post , but I didn't see you go back and say you actually followed through with that yet, or maybe you did and I missed it.
Old 11-04-2010, 10:06 AM
Thanks guys. I'll grab a few pictures when I get back this afternoon, it looks even crazier in the sunlight.
lol, I didn't mention it here? Well let's fix that. I used the Outback rear links, cut them in half and threaded the shaft. I made a coupler in the machine shop, put them together, and welded a tab onto the control arms.
shotgunslade and I had a good discussion about this in another thread. Modifying the endlink mounts like this effectively softens the swaybar a fair bit, but I do have another version in my head that may take car of that.
Old 11-04-2010, 10:53 AM
92 SVX 92 SVX is offline
That looks very good, I can't wait to see the pictures in the sunlight.
Old 11-04-2010, 01:20 PM
Pardon the iPhone shots, I don't have access to a proper camera at the moment.
Old 11-04-2010, 02:43 PM
Man that's awesome.
Old 11-04-2010, 03:42 PM
Yes, im very jealous.
Old 11-04-2010, 04:01 PM
Looks Great!
No way I could get away with having a car that low where I live though.
