Old 10-01-2007, 07:08 AM
k0ck3n k0ck3n is offline
Send a message via MSN to k0ck3n
Need help with a begginers thing
I wounder if you guys can help me with what looks like a basic thing (did not find any other thread about it)
I needed to change brakerotors on my car, and then I discovered that on my driveshaft the rubberseals are damaged (probebly the wrong name, but look on the picture and se what I mean).
So I removed the driveshafts and order new parts, but now and don't know how to remove the gear (big metallthing on the end so I can put on a the new part. Do have to remove the gear in the other end (gearbox end) or am I missing something here?
*..::\k0ck3n/::..*
My veichles:
Subaru SVX -92 [silver]
Suzuki GSX750R -98
Armybicykel -00
Yes, I live in Sweden, No it's not Switzerland, No we don't have polarbears on the streets.
Old 10-01-2007, 07:22 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Yes. You have to remove the joint at the gearbox end.
The joint at the wheel end cannot be removed.
My local garage had an easier way. They use a special stretchy rubber boot that can be fitted without removing the joints from the shaft.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 10-01-2007, 07:47 AM
There is a spring pin that holds the stub into the axle at the right end of the the photo. Use a 3/16 inch punch to drive it out. When you go to drive it back in, make sure you have it lined up properly. If it is 180* off, the hole will half line up.
Old 10-01-2007, 08:16 AM
Thanks, I will jump to it later this afternoon and hopefully it will be on the road again short after that.
*..::\k0ck3n/::..*
My veichles:
Suzuki GSX750R -98
Armybicykel -00
Old 10-01-2007, 10:38 AM
Manarius's Avatar
Manarius Manarius is offline
For all that effort - I'd just replace the halfshaft...
-Jason
-Obi Wan Kenobi
Old 10-01-2007, 11:00 AM
b3lha's Avatar
Phil & Belha
SVX parts are very expensive and hard to come by outside of America. In Europe, you can't just go to the nearest breaker and pick up a part. If you try to import parts from America you get stung on shipping and import taxes (but sometimes it still works out cheaper than the local dealer).
Old 10-01-2007, 11:47 AM
True, my new brake rotors cost me around nearly $720 with brakepads, I looked to buy pirate from US, but with shipping it would be more expensive. So if it works or are possibel to repair I won't buy a new one
After I have put them (both sides) togheter again I will leave them to a company that will balance them, and then they will be as new for $30
*..::\k0ck3n/::..*
My veichles:
Suzuki GSX750R -98
Armybicykel -00
Old 10-01-2007, 03:17 PM
Manarius's Avatar
Didn't notice he was out of the US. You're right about that though.
-Jason
-Obi Wan Kenobi
Old 10-01-2007, 06:53 PM
Hondasucks's Avatar
Subaru Technician
oh and the outer joints DO come apart if you whack it hard enough (been there done that) but you have to replace the snap ring that holds it together, so only do it if you have a BIG brass hammer and a new snap ring, but since you're replacing the inner boot anyway, just leave it together. Make sure you get all the old grease out of the joints and pack the new grease in there good :-)
(And make sure you have the boot and such on the outer joint before you put the inner one back together )
1986 VW Jetta
Old 10-02-2007, 04:12 AM
Yepp, When I have got them apart I will clean them in the washing machine at work, it's a industrial washing machine for metalparts. I don't think the bearings will be damaged by that, as long as I put good new grease on them afterwards.
I take that as a compliment, my english can't be that bad
*..::\k0ck3n/::..*
My veichles:
Suzuki GSX750R -98
Armybicykel -00
