Old 08-20-2007, 08:07 PM
jeffast jeffast is offline
I kill more trannies then god
Blew My Transmission Today...
i was driving to work and heard a sound like two sheets of rubber rubbing against each other, loud squeaky and not good, then 100 ft down the road i slowed down then took off and it went ot shif out of first, and clunk then no second free revved i bumped it into neutrail, then back to drive then third, second and first no responce no matter what, looking like it's time to start the 5 speed swap
1991 xt6 eg33?
1993 gc track car
Old 08-20-2007, 08:46 PM
Does it have fluid in it?
Old 08-20-2007, 08:59 PM
onestly i havent checked, it wasn't leaking any.
however i just started it and put it in reverse and it made a loud grinding noise no matter what gear i tried aside from neutral and park, so i'm going under that asumption that it is totally boned right now
1991 xt6 eg33?
1993 gc track car
Old 08-20-2007, 09:11 PM
does the speedo rev but the car go nowhere??
Old 08-20-2007, 09:31 PM
well thats what it did this morning when i left for work, wait, do you mean speedo, or tach, because the speedo reads normally and did for the whole tow home, when i gave it gass this morning the motor it just acted like it was in neutral.
tonight just for kicks i started it to see what would happen, and it rolled forward like 5 feet with out a problem, acted normal no matter what gear i put it in, then i put it in reverse and it made this loud grinding noise and continuse to make it in all gears now
edit : useful additional information, the front diff has been pretty noisey and getting worse as of late, so currently i'm thinking i blew the diff
1991 xt6 eg33?
1993 gc track car
Old 08-20-2007, 10:39 PM
poor claret. guess the cd player is on hold now.
Old 08-20-2007, 10:47 PM
actually my car has a cdplayer i am still gonna buy it for a birthday gift for my sister for her teal 96 ls,
1991 xt6 eg33?
1993 gc track car
Old 08-20-2007, 11:01 PM
yeah... front diff went kablewy... If the speedo revs with the engine like it was supposed to be moving, you have a spider gear failure in the carrier which i have seen happen a couple times... If the speedo reads 0 you probobly roasted either the ring or pinion on the front diff
Old 08-22-2007, 12:28 AM
crotchrocketony's Avatar
crotchrocketony crotchrocketony is offline
find one of the many people that have blown theyr trans but the diff is good and swap it...its easy, I did it on mine... had a issue with a seal leaking in the diff but that was my buddy acting like a butcher....it would be much cheeper then doing the 5 speed swap......unless your trans was acting up.....
1992 SVX black/redish 62k awd, rims, brakes..and a few add ons for extra HPs
Old 08-22-2007, 11:40 AM
i just plain flat out hate auto's, i already have about half the stuff required for a 5spd swap,
1991 xt6 eg33?
1993 gc track car
