ECU and TCU pin-outs
Does anyone have, or know where i can get, the pin-out's of the ECU and TCU? Also if you could tell me where they're located in the car as well it would be greatly appriciated. Thank you.
*No SVX at the moment...* 1987 Winnebago Elandan 35' 2001 Yamaha Roadstar 1600 2004 Ford Excursion Eddie Bauer, 6.0litre Power Stroke Diesel - Daily Driver. Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways, scotch in one hand, body thoroughly used up, totally worn out and screaming HOOOOYA !!!!! |
http://serial.cc/pdfs/ELETRICAL_COMPONENT_LOCATOR.pdf
This has a bunch of electrical boxes and ecu's but is there a main ecu that might be under a different name?
Put your head down by the brake pedal and look directly upwards under the dash. You will see two boxes next to each other about 6 inches by 4 inches by an inch deep with a zillion wires coming out of them. The one with the yellow plugs is the ECU. The one with the black plugs is the TCU.
Subaru ECU and TCU Website 1992 Alcyone SVX Version L 1992 Alcyone SVX Version L 1994 Alcyone SVX S40-II 2004 Subaru Legacy 2.5 SE Sports Tourer 1996 Subaru Legacy 2.2 GX Wagon 1988 Subaru Justy J12 SL-II Last edited by b3lha; 06-20-2007 at 11:50 AM. |
