Burning Rubber Smell?
Probably a stupid question for which I should know the answer, but why would a burning rubber smell be coming from my rear passenger side wheel? It coincides with the red break lamp warning light coming on sometimes when I break, particularly around a corner. Is it the rotor or something else?
“Veni, Vidi, Vici.” |
The STOP LAMP warning light informs when a bulb is blown. If it doesn't illuminate every time you step on the brake pedal, there must be some other fault in the system. It doesn't have anything to do with the mechanical workings of the brakes.
dcb |
Oh I do get worried when I smell rubber burning.
The brake light in my SVX comes on when the level is low in the fluid reservoir. It is an easy check and fix. Smelling anything out of the ordinary gets me nervous. How does any smell get in the SVX? It has to come thru the air supply system to the cabin by way of the grate under the wiper blades. Well if the windows are closed and the a/c is on. If it does not come in from outside then it has to be in the cabin. Ruber does not smell electrical er ah as in burning wire insulation which is the one smell I always wait for to go away and then say GREAT it was some one else in front of me Rubber smell? Can it be you are taking the corners at a good clip and the front is doing a little understeer??? Then you would smell the tires sliding. Maybe one of the engine belts is a little loose......... Easy check too !! How's the clearance to the back of the crank pulley where it would rub on plastic T-belt cover? Take care, John
A brake line leak onto the hot rotor can cause that smell. Check around to make sure there's no "extra" fluid under the car or on the rear axel.
*No SVX at the moment...* 1987 Winnebago Elandan 35' 2001 Yamaha Roadstar 1600 2004 Ford Excursion Eddie Bauer, 6.0litre Power Stroke Diesel - Daily Driver. Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways, scotch in one hand, body thoroughly used up, totally worn out and screaming HOOOOYA !!!!! |
I sometimes smell gas. With my old '92 (not the one I have now) I smelled burning rubber and heard noise right before the timing belt blew. Anywayz any burning smell does make me nervous.
-Ryu Links: 2004 Honda S2000 (2008~) 1992 Subaru SVX LSL Liquid Silver (2007~2008) 1996 SVX LSi Bordeaux Pearl (2006~) 2002 Lexus IS300 Sportcross (2005~) 1992 Subaru SVX LSL Pearl White (2001~2005) 1994 Mercury Sable GS (1999~2001) 1/43 Scale SVX Models [SIGPIC][/SIGPIC] |
Its not the smell you need to worry about, its the flames
11/94 SVX Alcyone, Mica Black, VL Spec 4WS, 71K Miles, 1 owner from new & was part of a private car collection in Japan. Nissan R34 Skyline Stagea 91 Lotus Elan SE Turbo 1966 MGB Roadster, Tarten Red, Wire Wheels, Leather, 23K miles from new You can tell the men from the boys from the speed of their toys. |
dcb |
