Old 05-10-2007, 06:39 PM
UPnorth362's Avatar
UPnorth362 UPnorth362 is offline
Send a message via Yahoo to UPnorth362
Kick pannel plugs?
Hi all....
Can some on please tell me what these 5 extra sets of connectors are for. I know the yellow plug is for the select monitor, but not sure about the others.
Thanks
IT'S 5:00 SOMEWHERE!!!
92 Liquid Silver SVX LS-L
Old 05-10-2007, 06:50 PM
SomethingElse's Avatar
word words wording
1 I dont know
2 used for onboard diag blinky check engine light
3 climate control celcius or ferinheight disply
4 i dunno again
5 grounding pins for checking and clearing codes
Eric
Old 05-11-2007, 05:26 PM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
The Plug that you have labelled 1 is "Check Connector (Manufacturing) B34".
Presumably they use this to test the control units before the car leaves the factory. It duplicates the wires in the yellow select monitor connector B35 and the black diagnostic connector B36 (#2 in your picture). There are also some other wires running from it to the ABS, Cruise, TCU, Steering and Airbag units. I've never seen the pinout of B34 documented, so I went through the wiring diagram and I've listed them below.
B34 Manufacturing check connector pinout
1 ABS
2 ABS
3 ABS
4 ABS
5 Cruise = B35-4
6 TCU
7 Steering = B36-7
8 ??? not connected on my car
9 Airbag
10 ABS/TCU
11 ABS
12 ABS
13 Receive Data (ECU/TCU/Cruise/AirCon) = B35-3
14 Transmit Data (ECU/TCU/Cruise/AirCon) = B35-2
15 ??? Possibly +12v
16 Ground
17 ECU = B36-1
18 Steering = B36-5
19 ??? not connected on my car
20 Airbag = B36-3
B35 select monitor connector pinout
1 ??? not connected on my car
2 Transmit Data (ECU/TCU/Cruise/AirCon) = B34-14
3 Receive Data (ECU/TCU/Cruise/AirCon) = B34-13
4 Cruise = B34-5
5 +12v
6 ??? not connected on my car
7 ??? not connected on my car
8 ECU
9 Ground
B36 diagnostic connector pinout
1 ECU = B34-17
2 ECU
3 Airbag = B34-20
4 4WS
5 Steering = B34-18
6 Steering
7 Steering = B34-7
8 Seatbelt
9 Airbag
10 Ground
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 05-11-2007, 07:18 PM
Phil,
You have gone to a lot of trouble and this data should not be allowed to become lost, It should go in the "How To" section.
Regards, Trevor.
Old 05-11-2007, 09:29 PM
UPnorth362's Avatar
Phil...
You are the man. That is a great write up, and a huge help. I agree, it should go to the books
Thanks again
Old 05-11-2007, 11:32 PM
Originally Posted by Trevor
Phil,
Regards, Trevor.
I am on this already!
Old 05-12-2007, 02:35 AM
EARLY bird is on the ball.
Old 05-12-2007, 06:51 AM
word words wording
1 ABS
2 ABS
3 ABS
4 ABS
5 Cruise = B35-4
6 TCU
7 Steering = B36-7
9 Airbag
10 ABS/TCU
11 ABS
12 ABS
13 Receive Data (ECU/TCU/Cruise) = B35-3
14 Transmit Data (ECU/TCU/Cruise) = B35-2
16 Ground
17 ECU = B36-1
18 Steering = B36-5
20 Airbag = B36-3
2 Transmit Data (ECU/TCU/Cruise) = B34-14
3 Receive Data (ECU/TCU/Cruise) = B34-13
4 Cruise = B34-5
5 +12v
8 ECU
9 Ground
1 ECU = B34-17
2 ECU
3 Airbag = B34-20
4 4WS
5 Steering = B34-18
6 Steering
7 Steering = B34-7
8 Seatbelt
9 Airbag
10 Ground
holy cow!! thats way better than my answer
Eric
Old 05-12-2007, 10:02 AM
Anybody know what #4 is? Thought I would label that before I finalized the page. Thanks
How about the white plug at the bottom of the picture that has black, white, red, and green wires? Anyone know what that one is?
Old 05-12-2007, 12:46 PM
UPnorth362's Avatar
The White plug at the bottom of the screen is for the select monitor and data logger that runs on my in car pc. It plugs into the select monitor port.
Old 05-12-2007, 01:45 PM
b3lha's Avatar
Phil & Belha
I can't find that one on the wiring diagrams. Somebody will have to follow the wire and see where it goes. (Or do it the quick way - connect 220v and see where the smoke comes from ).
Old 06-11-2007, 09:10 PM
I have asked about this wire in the past as well and never got an answer either.
