Old 05-03-2007, 12:02 AM
mojocoggo's Avatar
mojocoggo mojocoggo is offline
Send a message via ICQ to mojocoggo Send a message via AIM to mojocoggo Send a message via MSN to mojocoggo Send a message via Yahoo to mojocoggo Send a message via Skype™ to mojocoggo
Potential buyer - need advice
I'm looking at a 1996 SVX with about 103k miles. It's only had one owner, complete service records, and I've seen the carfax and it's all very good and seems to be well maintained. Is there anything specific, at this milage, I should ask about/look out for? This would be my first Subaru. I currently drive an '88 BMW 535is (avatar). Any pointers would be appreciated, thanks!
Old 05-03-2007, 01:55 AM
Noir's Avatar
Noir Noir is offline
howdy. i'm not trying to be a jerk but you can find loads of info on that very topic with the 'search' function. you'll probably get more info that would have been left out by someone just randomly mentioning stuff.
Old 05-03-2007, 06:08 AM
mikecg's Avatar
mikecg mikecg is offline
On a 96, check the rear wheel bearings. All SVXi seem to have issues with them. The early ones have tranny issues as well, but I think that was worked out by the 94 model year. Also, check the operation of the sunroof.
Old 05-03-2007, 06:31 AM
dcarrb dcarrb is offline
Here's what my SVX needed when I bought it @ <104,000: Radiator, AC hose, rear wheel bearings, PS return hose. The alternator and front half-shafts had recently been replaced. Within the first couple of years I needed a coolant temp sensor and crank pulley. With these items, mileage is more of a factor than model year. Good luck.
dcb
Old 05-03-2007, 08:51 AM
JaySVX's Avatar
JaySVX JaySVX is offline
Be sure to check the fluid levels, look around the engine bay and look for possible leaks. Wheel bearings, tranny, engine mounts, tranny mounts, suspention. Also be sure the front Llama guard is operational, royal pain to get replaced.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 05-03-2007, 12:47 PM
It's Just Eric's Avatar
Missing in action
Llama guard?
..Make sure the muffler bearing is good..(seriously)
Also make sure the wheels are on forwards, otherwise when you post pictures, everyoe will point out "Your wheels are on backwards"
Slightly more serious checklist...
-Matinence records are a BIG plus
-Transmission:Though its a later year and should be alright, make sute it shifts smoothly, ect.
-check all the fluids. oil, atf,and diff fluid are key
-make sure theres no cracks in the windshield, its a very expensive part
-Make sure there's no noise from the rear wheel bearings. Some svxi are fine, others are plauged by bearing problems
-oil leaks: Valve cover gaskets and front seals. Fairly typical for a 10 yar old car, but will require replacing nonetheless
-brake rotors may be warped
-Check radiator top tank for cracks / leaks
Also some more benign problems that are typical
-Bad hood and trunk lifters
-sunroof may need a light push to get it opening
-check out for any excessive wear on the seats, steringwheel, ect.
-paint may be faded / peeling from mirrors and plastic peices below rear windows
Being you say its a one owner car with service recors, and well maintained...Id say all is well. Just check out them records and see if the timing belt and other 60k matinence was done
R.I.P Cool Signature.
Old 05-03-2007, 01:29 PM
thumper_svx's Avatar
thumper_svx thumper_svx is offline
Either committed, or should be
Send a message via ICQ to thumper_svx Send a message via Yahoo to thumper_svx
I'll pretty much reiterate what everyone's said so far. I bought a 96 LSi as well at around 100K miles, and here's the problems I've had (misdiagnoses notwithstanding!)
  • Window switch for passenger side front on drivers door only brings window up, does not let it down
  • Killed the stock speakers (front)
  • Knock sensors (both)
  • Loose heat shields
  • Cracked resonator
  • Loose baffle in the muffler
  • Blew front seal and cam seal (oily!)
  • Headlights going yellow!
  • Both rear wheel bearings
  • One front wheel bearing
  • Dead battery
This sounds like a long list, but for an 11 (actually almost 12) year old car that's not half bad. Note that my radiator and all hoses were replaced before I got the car, and that I've owned three SVXi... if I don't know how to care for them by now I'll never learn
Hints for long life? Oil changes ever 3-5000 with GOOD synthetic, check (smell) transmission fluid at every gas stop (first sign of burning smell, get your transmission serviced... or every 25K or so failing that). Good quality air and oil filters are also a must... though if you use a K&N or some other oiled cotton air filter then be sure to put their oil on SPARINGLY when you clean it or you'll foul up your MAF.
Beyond that, they're great cars. They're heavier than they look, but the weight's down low. As a result, you can throw the car around quite a bit, but if you feel the traction start to break then be careful; the mass will work against you once traction's gone.
I almost sold my latest SVX about a month ago... I had stored it for a year and didn't feel like fixing it. However, once I did a couple of repairs and started driving her again the old addiction was back. Now I've started upgrading the sound system; I'm an hopeless case
Good luck!
Oh... and if you buy then stick around here. The advice you'll get from most of the members is invaluable... and the friends you'll make are worth their weight in wheel bearings
Ich bin ein SVXer wieder
My Rides:
Red 1996 SVX LSi (Saffron)
2007 Yamaha FJR1300 (Kaitlin)
Previously owned; green '95 L AWD (sold), black/pearlie '94 LSi (too many problems), Polo Green '96 SVX LSi (apparently notThe end of an era)
Member #2 in the Yahoo! club, been here since the beta-testing days. In dire need of a cheaper hobby.
Old 05-03-2007, 04:13 PM
As you are new on the board, it's hard to know where everything is.
Have a look in the information folders in this particular How-To folder
There is even a page on things to check when buying.
Old 05-03-2007, 09:21 PM
mojocoggo's Avatar
Thanks guys, I've looked around this site and others a bit more. If I do end up buying I'll definitely be sticking around here!
Old 05-04-2007, 06:16 AM
Oh, one other thing I forgot to mention. If you do buy, you could do worse as preventative maintenance than to replace the timing belt. At 100K it's likely it's either never been replaced or it's been a while. Either way, replacing a timing belt is a relatively easy and relatively cheap way to ensure that things are running well.
Just my 2c... never had a timing belt break on an SVX, but I have had one break on a Honda. That wasn't pretty
My Rides:
