Help me find link to slotted rotors
A while ago, I was in the forums when I ran across a link for drilled and slotted rotors with pads. I don't remember the exact price, but I thought it was a great deal. I think it was a website for Subaru parts, or SVX parts, but can't remember much more. If anyone out there can make sense about what I am talking about, please respond. Thanks
The best way to research the slotted / drilled rotors is to type in slotted rotors in the search feature at the top of the page. It will give you lots of threads to read about them. If you have questions then, post a question again and we will try to answer. This way you will get lots of answers to many of your questions and find out who sells them. Good luck on the search. The best thing you can add to your brake system is the stainless steel braided brake lines. There is no swelling when the brakes are applied and they feel much more positive when applied.
There are several sources of drilled and slotted rotors out there, including eBay and Race Concepts. Ben at Race concepts has been a friend of SVXNet for a long time and many of us have had his products. You mentioned drilled and slotted rotors and I would suggest that you consider your ultimate purpose when deciding drilled and slotted, dimpled and slotted, slotted only, or plain. There has been anecdotal evidence that drilled rotors are weaker than plain, or slotted. I am one of those anecdotes, having cracked a rotor during a particularly intense track day. If you intend to drive at speed on a track or Autocross, would suggest you look at dimpled and slotted or slotted only. If you are interested in appearance (assume you have more open after-market wheels) the drilled and slotted have more visual interest.
As for pads, I have to swear by Axxis ULT (Ultimates). The squeal a little bit, but have given me flawless performance at the track. Our front pads also fit a number of older Nissan SUV's and pick-ups, including the 1987-1990 van, the 1987-1995 Pathfinder, the 1998-2004 Frontier, and the 1985-1995 D21. I have sometimes bought pads listed for these vehicles instead of SVX's, because they were cheaper than the SVX nominal pad. Our rear pads are shared shared with 1990-1999 Legacies and 1992-1998 Impreza's, so they are also easy to find. Brakewarehoues.com has the best deal that I've found for Axxis ULT (new name) pad at $64.99 per pair. I have a set of front slotted FrozenRotors (cryo-treated) that I may be selling at Reading.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold Last edited by shotgunslade; 03-18-2007 at 10:28 AM. |
Nah, I'm an old guy with the original SVX rims ![]() Thanks for the info and advice. It is appreciated. |
I also was going to get some slotted/drilled rotors. The stainless brake lines: do they just perform better? Honestly thats not what i'm into as much as i dont want them to warp, i doubt i'll be hard on it at all, definitely not like autox or anything like that, what do you guys suggest?
Personally i've never had a car with stainless steel brake lines, and i've never had an issue, however they do look much nicer so if you have custom rims, that might be incentive to purchase them as well.
*No SVX at the moment...* 1987 Winnebago Elandan 35' 2001 Yamaha Roadstar 1600 2004 Ford Excursion Eddie Bauer, 6.0litre Power Stroke Diesel - Daily Driver. Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways, scotch in one hand, body thoroughly used up, totally worn out and screaming HOOOOYA !!!!! |
The FrozenRotors cost about $160 each. They have an unusual slotted pattern, but are not drilled. I installed them last October and they have one track day on them, along with about 2500 miles of street driving, and a winter. I'll probably be asking about $180 for the pair. The story on the cryo-treatment is that it is supposed to make them much stronger and resistant to cracking. This would only be of interest to those who will be abusing their rotors. One member here was talking about putting together a number of 0-120-0 cycles at maximum effort. The cryo rotors might be of interest for that activity, or the race track, or for someone who commuted to work over several thousand vertical feet of switchbacks everyday.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
http://cgi.ebay.com/ebaymotors/92-97...QQcmdZViewItem
By the way I just put these on my car and I am very happy with them so far! $164 for all 4 rotors and another $80 for all pads. I got them in a few days shipped through DHL ground, but I'm also in Cali so you might want to call them to see if they can ship UPS or something. |
From Earls post: ![]() "The best thing you can add to your brake system is the stainless steel braided brake lines. There is no swelling when the brakes are applied and they feel much more positive when applied. "
Life begins around 70 MPH and stops when you dont see the flashing blue lights anymore! Scott & Audrey's Subaru SVX's 1995 Green 1992 Black |
I just recieved my rotors and pads from iRotors, drilled and slotted, 220$ for 4 rotors and 8 pads. They seem like great quality, zinc coated to prevent rust. They're heavy and defidently don't feel chinsy. I will let people know once they're on how they feel and perform. picked them up off ebay, because i couldn't afford the nice ones they have, on a budget at the moment, plenty of repairs to do, not a lot of money.
Good luck and tell us howyou like them. They should not be all that much different than the ones that you would buy from them directly. Just a different price because they are on ebay.
Had the front's installed the weekend before reading, but the rear sliders were not cooperating, so i couldn't get them done, until reading. Sat out saturday night with a couple folks and we got them on. They stop great, though i have a bit of a squeel from the front, that i have to work out and see what's going on. They drag a bit when you first get them on, my guess is from the zinc coating, but after that wears off, and your down to just rotor and pad, they're great. They were 220$ + shipping, or 450$ + shipping if you want the ss brake lines, but the lines are available for 100$ for 4 from svx motor sports, so much cheaper to go that route.
My rotors + pads: http://cgi.ebay.com/ebaymotors/ws/eB...4608862&rd=1,1 They look good and feel good, but i may purchase ceramic pads, as i'm not sure that the pads it comes with are that great, but even without pads, it's a great deal for 4 rotors that have worked very well for me thus far.
Anyone here reset the braking bias to the rear a little more to smooth out your braking? I just go tmy SVX and am thinking of doing this.(NH has lots of curvy swirvy back roads and I like on and drive them to work.)
94 Bordeux Pearl LSi (Jun 2009) 109k Plate:GADDIS What they call it a vanity-plate. Shouldn't I be obligated to be vane with it? Rota Tarmac 3's 18x8" on 245/40/18 Dunlop SP Sport 600's, Perrin light weight crank pulley, PRW radiator, custom coilovers(not GC's), 9006 HID 4300k 50W low beams, DIY garage door lip, and SVXfiles brake kit. Fixxed exhaust so no more sweet sound. ![]() 97 White/Black trim Impreza Outback Sport (March 13/08) 150K-180K ![]() ![]() [SIGPIC][/SIGPIC] -Gaddis |
