Old 03-07-2007, 03:07 PM
sekler sekler is offline
Important question !!! Please help !!!!
Hi guys,
I just noticed a buzzing sound when my car (SVX '92) is turned off.
It seems to be coming from the ABS box area. I unscrewed the cover but didn't see anything strange.
I searched and symptoms look like it would be a bad relay ??
Should I unscrew one of my battery poles ?? I don't want to kill my battery, I need my car tomorrow !
please help !!
thanks
Old 03-07-2007, 03:11 PM
joburnet joburnet is offline
If it was me I'd put everything back together and take care of it this weekend as long as everything works. A battery charger works well and they are cheap.
Old 03-07-2007, 03:22 PM
everything is back together..I just removed the cover.
I just want to stop this sound and fix this the soonest possible..I need my car tomorrow, no time to deal with it later..
could this be just a fuse ? I guess with a fuse it would just be off since current doesn't go through ??
Old 03-07-2007, 03:42 PM
DarknessofDeath's Avatar
Inhabitant of Darkness
are you talking about the box that says "abs" on it. i think i had the same problem so i gave it a punch or two and it stopped.
Old 03-07-2007, 04:10 PM
it looks like it comes from the ABS area yes, but I can feel the buzz on the box and other parts, it's kinda hard to tell..I gave a couple of knocks with my wrench and it didn't seem to do nothing.
I unplugged one of the battery's poles
Old 03-07-2007, 07:35 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Pull out the relay to see if the sound goes away. If it does, replace it with a new one. I believe I had the same issue when I first bought my car.
Old 03-07-2007, 07:52 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Ya, it's a common problem.
Old 03-08-2007, 08:20 AM
**UPDATE**
Since I don'T know crap about mechanics, I just removed one of the poles of my battery.
Well I'll be damned, this morning I was about to bring it over to my bro who works in a garage...I plugged the pole back, no sound. Problem solved. ALSO, I had a problem with my remote unlock/lock system. The beeping sound was gone and I had to press the button twice with a few seconds between each press, otherwise it wouldn't unlock..now that'S solved too..could it have reset the alarm system and solved it too ?
so weird...when we say that a good night of sleep solves problems, it sure did it for me
Old 03-08-2007, 10:09 AM
Originally Posted by sekler
**UPDATE**
Well I'm glad your problems went away by themselves. Good result.
It sounds a lot like the software in your car was designed by Microsoft.
Old 03-08-2007, 10:42 AM
I always thought problems in a car happen or don't at all usually...no in between
is it possible that it was just a bug in the car'S computer ? it'S not as complicated imo..
anyway, I'm glad
Old 03-08-2007, 11:59 AM
Beav's Avatar
Not as old as Randy
Don't be fooled - the problem isn't solved. The relay will do this sporadically and can leave you stuck with a dead battery. Do yourself a favor and change it.
Old 03-08-2007, 01:37 PM
hey bud,
I guess it's still pretty hard to tell which one is faulty if it doesn't happen when I'm at the garage ? Unless there's only one in the abs area, is there anyway to test it eventhough it doesn't stick ?
thanks mucho
Old 03-09-2007, 12:13 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
you can bench test relays and find out an idea of their internal condition
- John
