Advise for amp power wire...
I am installing an after market stereo with 2 amps and was trying to find a way to run the power wire from the battery to the trunk and was surprized at the lack of grommets on the firewall to run it through to the cabin.I figured there would be a few on the pass for right hand drive versions.Am I missing something,has anyone out there drilled a hole through the firewall for this?
I tried where the main harnesses run through over the accellerator pedal and to the right of the heater hose,but I guess it's a two layer firewall in those areas.
Mike.... ![]() 8/96......Vin 100109 1997 LSI,18 inch Axis wheel(summer),16 inch ALT wheels(winter),Trans temp/Volt gauges,Iridium plug's, Autotechnica intake,silverstar high/low and fogs,polyurethane sway bar bushing's front and rear,Smallcar shift kit,Stebro exhaust finally..SWEET!! Motorsports drilled/slotted rotor's front and rear with ceramic pads and SS brake lines. 1997 SUS Legacy,finally got the engine in after a year!! My Locker www.myspace.com/devilhornz |
you could just drill a hole or take off the fender and route it with the rest of the wires (on the drivers side)
- John ASE certified Master Tech W/ X1 Twin City Fleet repair, St. Paul, MN need work done? Have tools will travel
I use the hole for the A/C drain on the passengers side foot well.
2005 Legacy GT 2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles ![]() My WRX's Cardomain Page |
Found a conveniently located grommet in front of both doors that leads in behind the kick panels,they are far enough foward the the door doesn't interfere with the wire,yet not hard to reach......finally a little closer to some better sounding music
Would love an SVX of my own... |
