Blinking Power Light Issue
Well I have the 16 blinks from the power light issue. It happens on start-up. It idles, runs, and drives perfectly. However, it is difficult to crank up again each time. It almost feels like it is a battery or alternator problem, but both are relatively new. Any clues?
Michael 1994 Barcelona Red SVX-LSI Two-owner:169K 1995 Emerald Green SVX L AWD #80 - Custom intake w/cone filter 99K with killer stereo system 2002 Acura MDX-Touring Edition w/navigation 2008 Toyota Prius 1987 Mercedes Benz 560SL |
Check the drop down resistor behind the battery under the hood. It should have about 6-12 ohms of resistance. There are directions in the how-to documents on reading the tranny codes and the engines. The power light only deals with the tranny though, So if your having running problems with the engine you'd better check the codes for the ECU. Good luck.
Thanks. I'll try that tomorrow.
