Old 01-06-2007, 04:46 PM
craftylandshark craftylandshark is offline
stereo head unit install - instrument panel??
I know I saw this exact issue a week or so ago but searching didn't seem to yeild anything. I just installed a new stereo head unit in place of one that was stolen. Now, some of my gauges don't light up (speedo, tach, enviro buttons), but thanks to a loose connection to one of my brake lights, i know that the trouble indicator lights still work. I didn't alter any wiring except for cutting the old into-head harness off and splicing the new harness straight in. I seem to remember the solution having something to do with the ground wire, but I could be wrong. Any ideas?
Kevin Crutchfield
Neophyte SVXer
92 LS-L Ebony/Lqd. Silver, stock, 88xxx miles, flung into a telephone pole by a drunk a month after buying
92 LS-L midnight black 141xxx miles, WRX FPR, MAF bypass, lightened underdrive pulley, formerly AppstateSVX's
Old 01-06-2007, 07:58 PM
Originally Posted by craftylandshark
I know I saw this exact issue a week or so ago but searching didn't seem to yield anything.... I seem to remember the solution having something to do with the ground wire, but I could be wrong. Any ideas?
Maybe this thread??
http://www.subaru-svx.net/forum/show...ghlight=ground
Old 01-07-2007, 11:39 AM
I looked at that thread to double-check, but that seems to be a totally different issue. If the ground plate wasn't in contact with my bracket, I'd have no sound. The stereo works perfectly. It's probably not a burnt out bulb - if it were, the needles at least would still be lighting up. I've checked the fuses and none of the possible suspects appear blown. If there IS a fuse at fault, I'm pretty sure it's got to be the #9 10 amp fuse in the cabin fusebox. Feel free to correct me, anybody. I'm going later to pick up a replacement just in case, but I'm really stumped on this one.
Kevin Crutchfield
Neophyte SVXer
Old 01-07-2007, 11:01 PM
fixed... the fuse was the bugger. very strange though, the wire looked completely intact from both sides of the fuse... definitely did NOT appear blown. bizzare.
Kevin Crutchfield
Neophyte SVXer
Old 01-10-2007, 06:43 PM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
... I didn't alter any wiring except for cutting the old into-head harness off and splicing the new harness straight in. ...
What a horrible thing to do!
People usually have problems with there being two Red / Black wires.
For anyone else who runs across this thread...
For Sale: Radio Wiring Harnesses for SVX!!
David C.
Old 01-11-2007, 04:01 PM
The previous owner had already done a cut-and-splice, so at that point, i figured i might as well do the same thing. It worked out fine, no issues with two red and black wires. Meh, who knows.
Kevin Crutchfield
Neophyte SVXer
