Old 12-30-2006, 01:38 AM
SVX10's Avatar
SVX10 SVX10 is offline
Fighting with electricity
Need some quick help
So, from my search I think I found my answer, but I'm gonna double check
Recently replaced a busted 4EAT with a not busted 4EAT. In the process, I pulled the new transmission's fluid pan and filter. So, I THINK the transmission was 100% empty of fluid after that.
I re-filled the transmission with 8qts of ATF, and it reads high on the dip stick. However, I know the trans takes 10qts full capacity, and I've NEVER been able to get an accurate reading from the dip stick.
Here's where I need help...
It won't shift out of 1st gear. I'm guessing my fluid is low. Would that cause this problem?
Thanks
Mat
Old 12-30-2006, 10:43 AM
Did you run it and then check the level again. There could be air in the lines and then once it get out of the lines, the level would be low again. Check to see if it is full again.
Old 12-30-2006, 06:17 PM
SVX10's Avatar
Well, the dip stick still read fine, but on that transmission I've never been able to fill according to the dip stick. I added 1.5 more qts (total of 9.5) and she shifts great. WOOOOOO!
Old 12-31-2006, 03:38 PM
I am glad to hear that solved the problem.
Old 12-31-2006, 06:13 PM
ShiuludeSVX's Avatar
Seems like
Seems to me, the books say that a dry system is 13 qts.
I could be wrong, but I found it funny the first time I saw it too.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
