Old 12-04-2006, 08:31 PM
etz bseder etz bseder is offline
Wiring Harness
I recently bought a used harness from one of the guys on here, and was wondering if anyone had a list of what the colors are supposed to corrospond with.
I have white, gree, purple, grey, orange all as a pair (one wihout and one with a stripe) then i have a black, red, and blue.
'92 LS-L, exhaust, intake, audio, ecu 1V4?, hyper ground kit.
Next changes ... PAINT, fix engine problems, 4.44. (GONE)
'97 Impreza Outback Sport, magnaflow muffler, cold air intake, Alpine Type S, MP3/iPod deck, NGK wires, etc.(GONE)
Old 12-05-2006, 04:59 AM
nysvx10 nysvx10 is offline
just match up the colors with the stereo, but in general:
black is ground
blue is antenna/amp
orange is illumination
red is ACC
yellow is battery
white,gray,greens, and purples are for speakers, make sure you have the polarity right though.
Old 12-05-2006, 08:03 AM
Alright, and if I have a sub, does that have to be turned on only when the auto-antenna is powered on?
Old 12-05-2006, 08:58 AM
Are you going to be powering the sub by a amp?
Old 12-05-2006, 10:05 PM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
There's a wire color / pinout table here: SVX Audio Installation Guide
You'll want the sub to turn on whenever the head unit is on, not just when the antenna is up. On most HUs, the antenna remote control turns off (lowers the antenna) when you switch to CD or Aux.
If your HU has an amplifier remote control wire then use that. If not, you'll have to control your sub from the +12V accessory line (so it will be "on" whenever the ignition key is on, regardless of whether your radio is on). If you think you'll drive around a lot with the radio off, you can add a switch to this wire to disable the sub.
David C.
