Go Back   The Subaru SVX World Network > SVX Main Forums > Technical Q & A > Chris's SVX Shop
Old 11-16-2006, 08:53 AM
jen jen is offline
Transmission Fuse
Hi all, hope you can help. My transmission is "catching" producing a bumpy grabing feeling when turning. The trans shop says the transmission is not damaged yet and when they reset the computer to test, the problem went away. My mechanic says it is a fuse but the SVX reference says the fuse is separate from the normal fuse boxes and is on the right side of the car. We can't find the fuse to replace. 92 SVX
Can someone please tell me where to find the fuse for the transmission?
Old 11-16-2006, 10:50 AM
There is a FWD fuse under the hood. It almost sounds like the AWD is binding. By default the fuse is missing. If you insert the fuse you will force front wheel drive only and if your symptoms go away you've found the problem.
Old 11-16-2006, 11:04 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Sounds like binding to me.
The fuse is on the Driver's side engine compartment. If you insert a 5A fuse, it will disable the AWD and if the problem goes away, you have a very common problem. I drove around with the fuse in for about 30K before the tranny finally died, but officially, the fuse should only used for diagnostics and not for everyday driving.
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 11-16-2006, 11:12 AM
Manarius's Avatar
Manarius Manarius is offline
Doug
You were lucky. Odds are, you have torquebind. Having the FWD fuse in is not a solution, just a way to stop imminent disaster.
-Jason
-Obi Wan Kenobi
Old 11-16-2006, 12:29 PM
jen jen is offline
trans fuse confusion
Ok, as I understand the previous posts
1. the trans/awd fuse is located in the normal fuse box under the hood. correct?
2. there isn't supposed to be a fuse in the trans/awd place? If there is then it disables AWD?
3. What is the common problem (the computer signaling the grabbing)- how do I fix it, if it is not the missing fuse.
Note the tranny was rebuilt about 5000 miles ago.
Thank for your replys and patience, I'm jsut not sure how to proceed. The car worked fine when the computer was reset - at least on the way home. So how would I fix tourque bind. The tranny people said I needed to fix the underlying electrical problem that was messing up the normal computer function. My mechanic says it appears tobe a fuse problem. What is impending disaster?
Old 11-16-2006, 01:48 PM
mohrds's Avatar
Correct. On the Cover it says "FWD" for that slot. Thinking back, it may be a 10A fuse, not a 5A as I stated earlier
Correct.
The famous Solenoid "C" inside the rear of the transmission. When this starts to fail, pressure sneaks through and increases torque to the rear wheels. I believe the only part you need is the valve assembly/transfer clutch, P/N 31942AA090. It may only be a broken wire inside, but as long as you have it apart, replace it. Runs about $90.00.
Here is a good discussion about it:
http://www.subaru-svx.net/forum/showthread.php?t=35657
Here is a great How-To:
http://www.subaru-svx.net/forum/show...2&postcount=23
You will need to drop the exhaust, the driveshaft and the rear third of the transmission to get to the solenoid/transfer valve (all one unit) Its about a three hour job.
Still under Warranty? (Fingers Crossed)
Probaby not a fuse problem
It involves a tranny rebuild / replacement
1994 LSi (4/93)
2000 Ford Excursion
Old 11-16-2006, 02:17 PM
Manarius's Avatar
I think it's this: http://legacycentral.org/library/torquebind.htm
Not Solenoid C problems.
-Jason
-Obi Wan Kenobi
Old 11-16-2006, 02:26 PM
I'd like to see svxfile's opinion of this. He has done more 4.44 tranny swaps and solenoid C replacements than anyone I know of. If anyone is familiar with this, it is Tom. He sure knows his stuff when it comes to binding issues.
Old 11-16-2006, 02:42 PM
jen jen is offline
Interesting discussion....
Ok, this is getting interesting. My question is with either of the suspected problems, why, when the computer is reprogramed does the problem stop?
I haven't noticed a flashing power light - would this happen if it was one of the cellenoid problems?
Old 11-16-2006, 04:51 PM
nordique14's Avatar
Who watches the watchmen?
You can easily check for stored codes. Check out the error code section for the TCU code how-to:
http://svx-iw.com/svxiw/article/?category=trouble
Of course if you reset the computer by disconnecting the battery then there will be no codes to pull until the problem happens again.
Too bad you are in Oakland. I do not know of any good shops in the North Bay. Take a look in the SVX Shop Search. There are some good places in the East Bay and South Bay. Also some places to avoid. Good luck!
-Matt
Old 11-16-2006, 05:10 PM
jen jen is offline
No codes
There wern't any stored codes. putting the fuse in the FWD solved the immediate catching problem. So now, which of the above solutions is the one to do?
Otherwise the car runs great. Please point me to the next step.
I'm in the east bay, Oakland, El Cerrito, etc. I had a great SVX tech at a dealer in New Jersey (there wasalso the scum of the earth dealer). I'd drive to find a good one but NJ is too far.
Old 11-27-2006, 07:31 PM
tierod tierod is offline
binding transfer clutch
Hi This is my first post. I have had some exp with this issue. Its also posible you have a problem with the tranfer clutch disc's wearing into the hub. This causes the disc's and plates to bind when applying. We have also tried a friction modifier (ford posi additive) and in some cases it's helped. After adding modifier, perform about 10 figure eights in a parking lot. If the problem persists
, take a look at your tranfer clutch hub. Hope this helps!
[IMG] code is Off
