Old 08-11-2006, 04:52 PM
viking64 viking64 is offline
Transmission
this is my first car with auto and have a few Q's
It appears that the SVX has a different config for AT in each country. With the gbox being 'electronic' what does this relate to? - does it learn continusly or are the gear changes just done by electric solinoids?
With the 'power' mode does this change the shift points or does it alter the ecu and remap the engine. (my power light come on with ignition, but does not seam to work when driving)
why was ours fitted with no econ mode and power switch - the oposite to JDM.
In the owners manual, what is the reason why the vehicle specs indicate that the Aus model and different hight (10mm higher than others) and camber specs to all other models - just curious
thanks
bruce
Old 08-11-2006, 05:34 PM
JDW-SVX's Avatar
JDW-SVX JDW-SVX is offline
it's ruby red - not burgundy!!
As far as I am aware, the transmission does not have a "learning" facility. The ECU does, though.
The "POWER" mode alters both the shift points, and the speed of each shift. It does not alter the behaviour of the engine.
The only electronic connection between the engine and transmission is the "Engine Torque Control Signal", which allows the transmission to briefly cut engine power during shifts.
If you are coasting at around 60km/h, and quickly apply the throttle, the "POWER" light should come on, and the transmission should kick down back to 2nd. Once you ease off the throttle, the light should go out.
Note that the "POWER" light is triggered depending on both the amount of throttle travel, but more importantly, how quickly the throttle is depressed.
The light is triggered by the Throttle Position Sensor - it may need to be cleaned or adjusted if the light cannot be triggered while driving.
I also noticed that the suspension height and geometry is unique to the AU model - I have no idea why!
Jason.
1992 Charcoal Grey SVX - 165,000km
1992 Ruby Red SVX - 165,000km
....now with sequential VIN numbers!
1986 Holden (Isuzu) Piazza Turbo - 225,000km
1993 Mercedes W140 S500 Coupe - 153,000km
1990 Mercedes W124 300D - 313,000km
EG33 + 4EAT + VTD AWD = SVX
Old 08-12-2006, 05:12 AM
KennEls KennEls is offline
The height is higher because Aus has some of the highest road camber of anywhere else. Most of Europe uses the std grade on the road of 1 in 50' or approx 20mm per m. Most older roads in aus are much steeper that this.
Kenn
