Old 07-14-2006, 08:21 PM
SVX JAZZ's Avatar
SVX JAZZ SVX JAZZ is offline
Tired
Question Does this sound like a timing belt issue or IAB valve?
When at idle (after my engine has warmed up) my engine has a slight vibration. This is mainly while at stoplights when the car is sitting in "D". It is not that bad but it is enought to rattle the stuff in my door handles (I put my sun glasses or cell phone there sometimes) or it causes a slight rattle in the plastic pieces in my interior. It doesn't matter if my AC is on either. Could my timing belt be a "cog off" or is my IAB (Idle Air Bypass) valve dirty? The car runs well and performs normal in all other ways.
Thanks for the help
Paul
1992 LSl (Black Mica)
1965 Mustang G.T. Fastback
1990 Mustang G.T. Convertible
1986 1/2 Nissan 4x4
2004 Vovlo XC70 (wife's)
Wonderful Wife
Wonderful Son
2 Cats
Incredibly blessed!
Old 07-15-2006, 08:18 AM
is the enine actually idling rough or is it more or less just a vibration. Bad motor mounts could cause a vibration like that
TOm
Old 07-15-2006, 10:44 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Timing belt - no.
IAC - no, unless it's idling at 300 rpm and about to stall.
Sounds like one or more misfires, to me.
Old 08-25-2006, 10:54 AM
SVX JAZZ's Avatar
Tired
Thanks
Thanks for the response. Car had been acting worse as far as performance. It is hesitating (more than usual) when cold and at low RPMS with the torque converter in lock-up the engine hesitates. I'm going to replace the fuel filter to see if there is any change. It's been a long while since I replaced it.
Old 08-25-2006, 06:46 PM
[QUOTE=SVX JAZZ]Thanks for the response. Car had been acting worse as far as performance. It is hesitating (more than usual) when cold and at low RPMS with the torque converter in lock-up the engine hesitates. I'm going to replace the fuel filter to see if there is any change. It's been a long while since I replaced it.[/QUOTE
I will back Beav and say coil/coils or plug/plugs.
Old 08-26-2006, 06:39 PM
SVX JAZZ's Avatar
Tired
Thanks, replaced those
Thanks, I tested and replaced two bad coils, replaced spark plugs and also put in new injectors about 2 years ago. The bad coils were actualy causing backfires. No backfires now just hesitation.
