Old 06-21-2006, 09:29 PM
cpelsy2k1
brake shields?
hey guys,
Has anyone ever noticed that their brake shields (right inside of the discs) scrape the discs while you are turning? Mine make a real annoying sound when i am turning while going slow. Either way has anyone removed them before? Would it be ok to do so? Thanks!
Old 06-21-2006, 09:33 PM
gtdanielgt's Avatar
gtdanielgt gtdanielgt is offline
I miss my VR-4
Send a message via Yahoo to gtdanielgt
Originally Posted by cpelsy2k1
hey guys,
I had an issue with this after putting on my s/d rotors and pads. You can bend the shield back a bit or remove it. Personally, I think they were put there for a reason, mostly to keep excess water and road debris off, but if you drive on dry pavement for the most part, shouldnt be an issue...
Insert Witty Quip Here...
No more subie
Current Cars: 96 Chevy Caprice Impala SS clone
93 Chevy Full-size blazer
Soon: 2002 Honda CBR 954RR
immortal_suby's Avatar
Thread Killah
Just bend them back don't take them off. They should not move when you turn though - they are mounted and move with the whole hub assembly.
Locker Link
2015 BRZ Limited 6MT
Old 06-22-2006, 04:47 PM
Scraping shields.
If the shields scrape only when turning, then the wheel bearings have too much freeplay. This allows the hub, and disc, to move to touch the shield. Check the bearings.
Old 06-24-2006, 12:34 AM
makalii's Avatar
makalii makalii is offline
Can the freeplay be adjusted, or is bearing replacement in order?
Gary
'92 "Beaujolais, nee Claret" LS-L ; ~180K; Build date 5/91, #1047
Old 06-24-2006, 05:22 PM
No they are like the rears, non adjustable preloaded, taper roller bearings, have to be replaced.
Old 06-24-2006, 06:15 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Not exactly! There will always be a certain amount of 'flex', some cars more, some less. GM is notorius for play in their wheel bearings, front and rear. Their notion is that a little play is o.k. and keeps brake rotor lateral run-out from being a vibration issue. Honda, on the other hand, is just the opposite. Large. tight bearings and hyper-sensitive to brake vibes. Most cars favor the Honda end of the spectrum.
Either way the cure isn't removing the shields. If the bearings aren't making noise and there isn't any discernable play in them just tweak the shields to keep them from rubbing.
Old 06-24-2006, 06:21 PM
Yes I suppose it helps to push the pads back, but not what I would call good engineering.
Old 06-24-2006, 08:44 PM
Beav's Avatar
Not as old as Randy
I agree, it's a shoddy practice. But what do you expect from the only company that has to shim their starters, for 30+ years?
