Old 06-01-2006, 04:49 PM
n00b on demand's Avatar
Window not staying up
Im having a problem with my passenger side window. It seems as though it is always a little crack open. You always have to lift the button so it can go up again a tiny bit. Not a huge bit open but just a tiny bit. What broken or not working? How expensive is this going to be to fix?
Old 06-01-2006, 05:37 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
sounds like the pane is alittle off the track just remove the side panel and adjust it
- John
Old 06-01-2006, 08:48 PM
Well that seems really possible. I've had to remove the door panel a million times to change out switches and change door speakers. When the window goes all the way down its definitley not as smooth going down as it used too. I will take the panel off and put it on as right as i can to see if that changes.
Old 06-03-2006, 02:39 PM
It's Just Eric's Avatar
Missing in action
Might be a messed up window regulator. Probly not too hard to replace if need be. Also, try using a silicone spray lubricant on the moving parts, as well as in any of the guided for the glass itself. Usually helps alot haha...refulator
R.I.P Cool Signature.
Old 06-03-2006, 02:52 PM
CDG's Avatar
CDG CDG is offline
No front plate on My SVX
Send a message via MSN to CDG
What's a refulator?
"Refulator"
I like it, just saying it is fun.
"Honey, we have to have sex now or my refulator will explode"
"Officer, I didn't mean to speed, but my Refulator broke"
"I left it right next to the refulator, can't you find it?"
Chris G
92 Pearlie, sold @ ~209k miles. Now owned by Tim.
Current Ride, 1985 Honda Aero 80, stock 3024 klms
Old 06-03-2006, 02:55 PM
CDG's Avatar
CDG CDG is offline
I searched , and there is indeed a "voltage refulator" in many cars. Wow, who woulda thought
Chris G
Old 06-03-2006, 03:00 PM
Missing in action
...this is the second time someone has d something weird I typed. First of course, being Nikfu searching for "Strewn about's worth"
Aparently, Im the only person to ever type those words in that order. Of course it looks ALOT stranger when taken out of context
Old 06-03-2006, 03:12 PM
CDG's Avatar
CDG CDG is offline
I guess your just that lucky, or you have a way with words.
Congrads on adding just a few more smiles to this happy little planet
Chris G
Old 06-03-2006, 06:31 PM
SubaSteevo's Avatar
No longer blue member
Tom, I'd definately check to make sure that the panel was on correctly. If the top was misaligned it could very easily be rubbing on the window.
-Steve
01' MSM Lexus IS300
Old 06-03-2006, 07:40 PM
Thanks I will do just that. I think it is misaligned...even tightening the screws on the door is difficult...so obviously something is not right.
