Go Back   The Subaru SVX World Network > SVX Main Forums > Technical Q & A > Chris's SVX Shop
Old 05-14-2006, 07:47 AM
ruffyone
sun roof sticks
The sunroof on my 92 SVX requires a gentle upward push before it will open. Can it be adjusted, and if so how? There is probably a clutch adjustment on the motor, but where is it located and how do I access it? Thanks.
Old 05-14-2006, 08:54 AM
laserx's Avatar
laserx laserx is offline
Just apply a bit of silicon spray to the seal around the edge, it will then work as normal.
Old 05-14-2006, 12:43 PM
dwd1985 dwd1985 is offline
If the silicone spray doesnt work, there is a bolt covered by a plastic clip right behind the sunroof. Pull off the plastic cover, and you will see a hexagonal bolt, tighten it (gently), and this will increase the torque setting for the motor.
Old 05-16-2006, 07:43 PM
SUBBYRU89's Avatar
SUBBYRU89 SUBBYRU89 is offline
Siren of the Pleiades
Send a message via AIM to SUBBYRU89
Try this..
14.708 in the 1/4 mile pre-KillerWail
'89 XT6 Pearl White~JuiceBox (Project)
'92 SVX BoverP~Peej (Down for the moment) 1st Stage II trans installed by AWD,15 & 20 min mods,...
Old 05-17-2006, 04:52 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Two possible faults:
There are small nylon bushings that ride inside grooves. These bushings break and disappear, causing the mechanism to catch on various edges. The down side is that the only way to repair/replace them is to completely remove the sunroof and disassemble. I used, of all things, aquarium air tubing (1/4" lengths) to replace the bushings. They've been in place for over a year now.
Even when everything is in excellent condition, the seal that surrounds the roof panel is a bit too snug on the SVX and will swell a tad during rainy periods. The swelling will slightly pinch the panel and keep it from popping up. Good news is that it will abate a day after the rain lets up.
Old 05-17-2006, 05:09 PM
I think the sunroof motors just grow tired over the years.
Old 05-21-2006, 09:30 AM
Beav's Avatar
Not as old as Randy
That goes w/o saying but mine was just like everyone else's until I completely removed it and repaired the trolley bushings. Now it works properly, every time, barring the period following heavy rains when the surround is swollen. There's a Subaru TSB regarding that issue but the concern is so minimal that I haven't revisited it.
Old 06-10-2006, 12:35 PM
intelisevil's Avatar
<<<Alcyone
Great, I live in the perpetually moist Pacific North West, so my sunroofs will never work properly . . .
Dan
Old 06-10-2006, 03:08 PM
Beav's Avatar
Not as old as Randy
I recall my first wife's sister's comment regarding the NW after returning from living in Portland for several years:
"No wonder everyone there is nuts, they never see the sun!"
Old 06-10-2006, 04:51 PM
<<<Alcyone
Not me . . . I was nuts years before I moved here!
Q - How can you tell the girl from Oregon?
A - She's the one with moss growing in her arm pits.
Dan
Old 06-12-2006, 07:48 PM
AutoTchr AutoTchr is offline
Dan
and an arse the width of an axehandle.............
ASE Master and L1 cert. Discounted Repairs
I feel a lot more like I do now then I did before.
92 SVX 5spd, (sold),92 SVX Teal, 67 Mustang 351C 5spd, 00 Galant.
[IMG] code is Off
