Old 04-25-2006, 11:27 PM
triumph1902's Avatar
triumph1902 triumph1902 is offline
What the hell is this?
Alright so I emptied the oil from the front differential, and I find this stuck to the magnetic plug...
At first I thought it was a chipped gear tooth or something but looking at it closely it seems to be a tiny spring split in 3. Could this be a part from the differential itself or something somebody could have dropped inside? A lil background on the trany.. it is a Genuine Subaru remanufactured.. that came with the car when I bought it. Looks to have been replaced maybe 20 to 30 thousand miles prior.
Old 04-25-2006, 11:36 PM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
That def doesn't belong in there... Thats about as much as I can help.
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
Check My New Homepage..
Old 04-25-2006, 11:45 PM
Speedklix's Avatar
Locker Link Solution
Looks like the a piece of a spring that hold the tension on the axle stub seals
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 04-25-2006, 11:46 PM
THAWA
Looks like a dime.
Old 04-25-2006, 11:48 PM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
what the fook
Brian
Old 04-26-2006, 12:17 AM
hmmm, that makes you wonder... why all auto trannies damages occur in the US
Old 04-26-2006, 12:27 AM
Ahhh..how come I didn’t think of that
I have the drivers axle off now (putting a new steering rack in) I'll take a look and see if the seals are in one piece tomorrow.
________________________
92 Teal - Work in progress
Old 04-26-2006, 12:34 AM
Its because out axle stubs are bigger
Old 04-26-2006, 11:52 AM
it is the seal's spring. Too small to be anything else. Crappy part is, you need to turn out the side plates to replace the seals which can throw off your ring/pinion alignment if not exactly to spec. Wish you all the best make sure you replace that seal or else it will leak
Old 04-26-2006, 03:17 PM
Ricochet's Avatar
I brought some ham.
I asked a friend of mine who is a mechanic and he concurs.
Brian
Old 04-26-2006, 04:08 PM
Oh no faith??
Old 04-26-2006, 06:57 PM
Ricochet's Avatar
I brought some ham.
No, I asked him at the time of my "what the fook" reply. It could have been a spring that holds the differential onto the transmission for all I know about these cars..
Brian
Old 04-26-2006, 08:37 PM
Thanks for the help everyone I checked the driver side and that one is intact so it must be the other one, although I see no sing of an oil leak.
Tom...If I mark the plate on the diff and than unscrew it counting every full rotation until it comes off and than install it the same way lining up the marks, would i be ok, or do you know any other way of doing it?
Old 04-26-2006, 10:21 PM
just be sure you have the revolutions right and you should be ok. Do both sides while you are in there
Old 04-28-2006, 12:18 AM
Will do! Thanks for the heads up...I would of probably had to find out the hard way.
