My car sucks
2 months after I got my car the front diff blew. I replaced it and the pinion gear. then one coil needed replaced. then the water pump siezed up, and blew a crack thru the top of the radiator, so I replaced the timing belt and idler, and the thermostat, and the rad. then because I put the timing belt back on wrong it jumped a couple of teeth. so I did it right the second time. Then the TPS went bad and I also got a CE code for both o2 sensors ( which I thought was because the TPS was so off). Well I replaced the TPS. Then the AWD wouldnt engage( but I dont think it ever really worked and that might have been why the front diff blew in the first place). So I put a fuse in between tcu and the solenoid c, so when I pulled it out I could put it in 4wd. It was mostly just to see if that would work, and it did. But there seems to be something loose or worn because my car seems to handle like **** when I have the 4wd on (even in a straight line). So I only had the 4wd setup for about 1 ride and put it back to normal. Now the car is throwing the 02 sensor codes again and the right knock sensor code. Also sometimes when I turn the car off, all of the lights that come on the dash when you put the key on, on come on, but they come on really dim. And now the trannsmission seems to be doing funny things, I was driving at about 75 with cruise on and the rpms suddenly jumped about 1grand then went back then did it again. I dont know if that was tranny related or not, but the car also seems like its taking off in 2nd and then it will jump into 1st at the last second. I dont know if thats what it is doing or not thats just what it feels like. I hate this car I have only had it for 1 year and I think it is going to be the last subaru that I will ever buy. What the hell is wrong with my car now??
1989 Subaru XT6 130k 1992 Subaru SVX 120k 1993 Ford Probe 30mpg 213k 1989 Subaru XT6 150k All good and running |
No matter how well a car is made, it'll be junk after just a few years if it's constantly thrashed and neglected. I've seen the odometers on two Subarus roll over 200,000 miles and have every reason to believe I'll see a repeat performance in my SVX. But it'll surely never make it if all I do is fill the tank and floor the acclerator. dcb |
the car has 125k but I dont know of its past owners. I havent even got a chance to thrash this car even if I wanted to. every weekend its in my garage with another part that needs fixed. Also the car is idling strange. sometimes almost dies while stopped and in gear was idling at 1500 then started idling at 900 w/ the shakes, now it idles up and down between 1500 and 600 rpms. After owning this car its hard to believe that any SVX is care free for more then a short period of time. I have a 93 ford probe with an auto tranny worse tranny in that type of car is the tranny in it. the current odometer reading on it is 210k and I have only had to change a broken belt and powersteering pump since I bought it two years ago(other then sced. maitinence of course). AND ITS A GODAMN FORD!! I hate my car.
The dim dash lights probably means your alternator is going bad. Get that changed first then see if the newfound current helps any of the other problems. Also sounds like your tranny is about to SHlT the bed.
You could sell the SVX to someone who doesn't mind taking care of it if you hate it so much. Sounds like you have a daily driver already in the Probe.
The car is 14 years old with 120k miles. Cut it some slack.
Dan M. Barcelona Red '93 AE #073 of 301, 168k miles. |
Spinn360
If you really hate your car that much, I could use a parts car . . . ![]() The strange idle could be as simple as a broken vacuum hose.
Dan Pentiums - Melt in your PC, not in your hand! Project - '92 Claret - Purchased May '06, 99,XXX Miles. Includes two bad engines and one bad tranny, cracked windshield, otherwise mostly complete. His - '92 Ebony Pearl - Purchased Dec '05, 134,687 Miles. Parked, TC Seal(?) is leaking.Daily driver - 140,500 and climbing. Hers - '92 Teal - Purchased Aug '05, 129,050 Miles. Daily driver - 160,000 and climbing. Mods: PWR Radiator! Problems: Antenna doesn't work - Bought a 'new' one - Too cold to install . . . OK, it's warmer but I have other projects too! ![]() Ticking from front of engine, passenger side - Stuck lifter? |
Well I still owe 3500 on this hunk of junk, so I will let someone take it when the price gets near whatever someone is willing to pay for a parts car POS
Actually well I guess it doesnt matter wether I fix it or not I am not putting one more cent into this money trap. I am going to drive the car in peoples blind spots until it gets hit or until the car craps out on me then the loan company can have it.
1989 Subaru XT6 130k 1992 Subaru SVX 120k 1993 Ford Probe 30mpg 213k 1989 Subaru XT6 150k All good and running Last edited by spinn360; 03-26-2006 at 12:06 PM. |
117k problem free miles on mine.....some of our cars are great.....most of them....like anything there are always a few bad apples in the bunch
1993 25th Anniversary Edition # 156 of 301 ~ 121, 488 miles ( SOLD TO svxfiles 8/6/06) 2006 Subaru Impreza 2.5i....5spd ![]() 2006 Subaru Legacy 2.5i -7k miles..Mom's daily driver 2,543 Member of the SVX World Network |
![]() You know my car might not suck so bad but the previous owner probably drove it like a race car and wasnt a mechanic(probably didnt know the difference between a turbo and a supercharger)
1989 Subaru XT6 130k 1992 Subaru SVX 120k 1993 Ford Probe 30mpg 213k 1989 Subaru XT6 150k All good and running Last edited by spinn360; 03-27-2006 at 10:39 AM. |
not enough 5speed in that car
![]() Tom |
Wish I had the money. but also wish I had never bought this car because I am a poor poor bastard and I dont have the money to work on it. Wish I knew what I was getting into before I bought the car. Next time I guess.
![]() ![]() ![]() Don't knock us ignorant non-mechanical types. Some of us really do try to take good care of our cars. As many people know, my baby got completely overhauled last year and is as good as new. Should last me at least another 100,000km. ![]() |
This is one of the worse examples I've heard of for continuous breakdowns. (Knock on wood).. Maybe it truly is time to send it down the line.
Robert Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me. Update: 09 January, and still not in jail! Wassup?? 1992 Teal LS-L - 160k (Now new and improved with perfect paint!) |
I dont know if I mentioned this but I also have to wiggle the key in the ignition to get the autoseatbelt to actually go back. If I dont it takes about 40 sec to initiate on its own.
I was thinking that this car needs to go to the scrap yard. who knows maybe if I just park it in my back yard for about a year I will forget that there was so many back to back problems. And then maybe I will try the 5mt and replace some sensors, and some vaccum hoses and maybe I could just pull the whole engine and do a rebuild and then maybe I will give it another year and say hey why didnt I finish (probably because I ran out of money) I only had a few problems and its almost good as new. Then I'll finnaly get the engine back in and the 5mt in and get it all together and it will probably need new shocks and some brake work and some new bushings. And by the time I am finally done ![]() ![]() ![]() ![]()
