Old 02-12-2006, 06:02 PM
Alternator Problems
Recently there have been posts about dead batteries, electrical drains and such. Some, including myxalplyx and michael, mentioned the alternator wiring mod connections touching the alternator, some talked about the visor wires, etc.
Add me to the list with an alternator problem;
Friday
We picked up Svxit's 92 pearlie at his house on Friday night. She cranked right up and we drove home with no problems.
Saturday
On Saturday morning the battery was dead, the warning lights came on, but not enough juice to turn the engine over. I thought it might be the battery, since svxit said it was A 4 year old Optima redtop. It went dead on him after lack of use for a very long time. He took it ti Advance Auto and they gave it a full charge, but told him it was on its way out. Once he put it back in the car he didn't have any more problems as long as he started it on a regular basis.
Anyway, I called the AAA Mobile Battery Service and they came out and jumped the battery. Then they ran their diagnostics and said the charging system/alternator were fine but the battery wasn't passing the three-minute load test. They replaced the battery with an Exide 770CCA and left. I drove it around the rest of the day, making numerous stops and restarts with no problems.
Sunday
This morning I went to start it and the battery was completely dead! No interior lights, warning lights, buzzers. Not even a click when I tried to start it. called AAA Mobile Battery Service again. Jumped the battery and ran diagnostics with different equipment. Battery was fine, but the alternator/charging system was failing their test. Let it idle for a while and shut it off, started it up later and everything was fine. Did this a couple of times.
What should I check? So are there definitive symptoms of a failing alternator? My electronics run perfectly, no odd electrical gremlins or warning lights. Belt appears to be tight and doesn't squeal.
So either the alternator is failing to charge the battery or there is something suddenly draining the battery overnight. I thought the alternator wiring mod connector touching the alternator case would produce a short, not a slow drain; same with the visor wires.
Any help is greatly appreciated. Does anyone have a good working alternator or links to a good rebuilding shop? My son is really geting bummed out-- two mornings in a row he has a dead battery.
Old 02-12-2006, 06:14 PM
John
It is a new battery and we can rule that out. It must be some kind of drain that draws it down over night. The only thing could be the alternator. I am not from that area, so can not give you a shop to go to, but a shop should be able to check the alternator for you and give you the answer. Good luck. I can imagine what his thoughts are when he comes out to the car with a dead battery.
PS I find that batteries are cheaper by the dozen.
Old 02-12-2006, 08:34 PM
michael's Avatar
michael michael is offline
What Potholes ???
Check out this thread,http://www.subaru-svx.net/forum/show...battery+drains
just be sure to either have a alternator shop undo and redo the solder or be sure you have a really powerful soldering gun 200 watts or a resistance soldering gun. Also check the wires going to the alternator they seem to crack from the heat above the engine. How much aftermarket equipment does the car have? Check that stuff out too.
Wanted: Steering Wheel
Old 02-12-2006, 10:14 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
After driving, Use a volt meter on the battery while the car is off. Take note of the reading, after an hour check it again. If the voltage droped, then something is draining the battery. If all is o.k, check the battery voltage before and after starting to see if the alt is working. Around 12V engine off and 14V engine on. Have the alternator checked while it is in the car. This is from my personal experience with a similar problem. Good luck!
Old 02-13-2006, 05:10 PM
Originally Posted by svxcess
We picked up Svxit's 92 pearlie at his house on Friday night. She cranked right up and we drove home with no problems. On Saturday morning the battery was dead, the warning lights came on, but not enough juice to turn the engine over.
Antway, I called the AAA Mobile Battery Service Saturday morning and they came out and jumped the battery. Then they ran their diagnostics and said the charging system/alternator were fine but the battery wasn't passing the three-minute load test. They replaced the battery with an Exide 770CCA and left. I drove it around the rest of the day, making numerous stops and restarts with no problems.
This morning (Sunday) I went to start it and the battery was completely dead! No interior lights, warning lights, buzzers. Not even a click when I tried to start it. called AAA Mobile Battery Service again. Jumped the battery and ran diagnostics with different equipment. Battery was fine, but the alternator/charging system was failing their test. Let it idle for a while and shut it off, started it up later and everything was fine. Did this a couple of times.
Hi John, it would seem to be a leak in the system. To drain a new,full battery over night, there would have to be a BIG leak. To check, you need to disconnect the battery terminal and connect an amp meter (at least 15amp) between the terminal and the battery lead. With every thing switched off, there should only be a small current, about 100 millamps flowing. Any more is a leak. To find the leak, you have to pull fuses one at a time, till the leak stops. Then find, which unit, that fuse operates.
Old 02-14-2006, 02:43 PM
UPDATE
Monday
I went out to start it in the morning and it started up like a champ! Anyway, I took it to Goodyear and had a complete charging diagnostic test done on it. Everything passed with flying colors. No problems the rest of the day.
Tuesday
This morning my son took it to school and once again it started up without problems. When he came home from school he asked me if it should be so hard to turn the wheels when the car is in park and the engine is running. He also mentioned a stiff, jerky kind of steering when turning, with an occasional squealing
I went out, started it up and it acted just as he said. I checked the fluid level in the PS reservoir and it was full. I then suspected a failing O-ring. Finally I checked the PS belt and it was VERY loose and probably slipping under load. I tighened it up quite a bit and the steering returned to normal.
The interesting thing is that this same belt drives the alternator pulley. I guess that is why the battery was not being properly charged. As of now the car is functioning normally. The only thing left to check is the drivers sunvisor. The light is out and I don't know if it is a bad bulb or a broken wire.
I will keep you posted...
Old 02-14-2006, 02:47 PM
How's the belt itself? If it's been slipping for so long it's likely damaged.
Old 02-14-2006, 03:20 PM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
Huh! My belt makes a whistling sound when it's loose.
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 02-24-2006, 11:45 PM
Problem resolved...
Well it's been 10 days since I tightened the power steering/alternator belt and no problems since.The car does not drain overnight, starts right up, the plug in voltmeter shows 14.4V at cold idle and turning accessories on shows the alternator is charging very well. Even the CEL which occasionally came on while driving, but went away after turning engine off and restarting, has not come back either.
Its hard to believe that a loose alternator belt could cause the new battery to drain overnight the way it did. But the proof is here.
Old 02-25-2006, 12:01 AM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Glad to hear your problem solved. It's very unbelievable a loose belt will drain the battery overnight? Doesn't make any sense to me yet...
For the last repair on my yellow one, Tom(cumberland) replaced my O-ring and PS main pressure line. After that, I have been noticing sometimes my Power Steering feels Jerky or Light/Heavy.....but my PS fluid is always clean and full. I don't have any battery problem for so long. The belt looks in good tension to me. I still have the same feel on the PS and I hope I will find out the cause one day
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 02-25-2006, 01:26 AM
I changed the O-ring once on mine and it got worse. I checked the O-ring again and I had got is put on so it still leaked air when it was on. I replaced it again and it has worked great ever sence. I would suggest replacing it again if it is still jerky.
Old 02-25-2006, 01:42 AM
Unless the belt was so loose that my alternator wasn't charging the battery at all and all of my electrical usage on the car was coming from the battery. Or that the new battery was not fully charged to begin with.
But then I should have felt the power steering acting funny as well during this period. I have no answer. I did not do anything else to the car but tighten the belt.
Unless the new pearlie finally realized who its new owner was and decided to shape up and stop horsing around.
Old 02-25-2006, 09:56 AM
You just needed to show it who is boss.
