1996 AWD SVX Dyno Numbers
Well, I must start this off by saying this was Chike's car that he sold me yesterday. I wanted to copy and paste the current mods (exhaust, cams, header, 4.44 gears) from what he may have posted up in another thread but I didn't see it in his link. Chike, chime in with info if you like.
Basically, I wanted to dyno the numbers to see where it stands now vs where it may/can be in the future. Dyno runs where done at Xotic motorsports in Cochranville, PA with a guy name Andy helping out. This is a Dynojet AWD dyno. Stock STi numbers are 245 -/+ 5hp from what Andy told me, 245-255 what he told Chike. Intake temps were checked with a laser temp probe and was about 77-79F (Plastic intake). Above the phenolic (sp?) spacers, the temp was 100-101F while below it was 122-124F. I did a total of five dyno runs. The first run was what I thought was 2nd gear but it actually ended up being 1st gear. That run will not be posted. The 2nd and 3rd run was done from the bottom of 1st gear to the top of 3rd gear. The 4th and 5th runs were done the same except that the two intake tubes were removed (per Chike) to test to see how the Maf bypass effects hp/torque numbers. Here are a few pics of the car on the dyno. Sorry for the pics that are not that clear. Here is a video of the car on the dyno. http://svx-iw.com/svxiw/videos/dyno/SVXDyno.MOV Without delaying, here are the dyno charts. 1st-3rd gear, All four dyno runs Notice that removing the two rubber hoses used for heating up the intake during started will net in 3-6hp. Sorry if the dyno image is a little to small. I had it larger but it stretched the screen. I'll fix it a little later. 1st-3rd gear, All four dyno runs, Only HP 1st-3rd gear, All four dyno runs, Only TQ 2nd Gear HP 2nd Gear TQ I'd post more info but this opens everything up to some talk and debate. Plus, this is my only day off and I have an intake idea I mentioned to Chike. I have to stop by Vertex Industries to discuss piping sizes NOW. So, I'll be back to add later. Oh yeah, this is in STD (Not sexually transmitted diseases ) format instead of SAE like I originally had the graph. SAE will make the numbers be about 5hp/5lbs-ft of torque lower across the board. It is in STD to compare apples to apples with Chike's previous numbers. Ok, I'm out for now.
Kevin Thomas 1997 2.2ltr Subaru Impreza Outback Sport Wagon (AWD/Auto) 13.03@100mph 1989 2.7ltr Subaru XT6 (AWD/Auto) 15.912@85.93mph 1996 3.3ltr SVX (AWD/Auto) 15.070@91.38mph ***R.I.P*** 2010 RAV4 AWD Sport (13.717 @ 99.19mph ) 2015 Honda Fit LX CVT (15.2 @ 90mph) Last edited by Myxalplyx; 01-27-2006 at 07:17 PM. |
Here's my dyno graph from when I dyno'd my former '96 (now owned by Myxalplyx) with the previous STD correction:
*Note*: SAE correction changed in '05 resulting in lower hp ratings. I dyno'd my car under the old correction factors, and Myxalplyx has shown his dyno results using the same standard. My pulls were done in 2nd gear on a dynojet and his comparative pulls were done in 2nd gear on a similar dynojet. -Chike
"Wise men talk because they have something to say; fools, because they have to say something." - Plato 2013 Cosmic Blue 5spd Evo X GSR 2006 Galaxy Gray 6MT RX-8 (sold) 2006 Steel Gray WRX TR (sold) 1996 Brilliant Red SVX L (sold) Last edited by Chiketkd; 01-26-2006 at 02:47 PM. |
Chike,
I have that movie of the last dyno run but I am out of space on my server. You know where I can host it up? I need to run out now before the sun goes down. I'll be back in a bit.
Kevin Thomas 1997 2.2ltr Subaru Impreza Outback Sport Wagon (AWD/Auto) 13.03@100mph 1989 2.7ltr Subaru XT6 (AWD/Auto) 15.912@85.93mph 1996 3.3ltr SVX (AWD/Auto) 15.070@91.38mph ***R.I.P*** 2010 RAV4 AWD Sport (13.717 @ 99.19mph ) 2015 Honda Fit LX CVT (15.2 @ 90mph) |
am I reading it wrong or did you not gain anything? The HP numbers look the same....
1992 Midnight Black LS-L - Sold 3/3/06 1991 Toyota MR2 - Sold 11/27/07 1992 BMW 325i - Tokicko Suspension |
Earthworm should be able to host it on his site. And can you explain the dyno sheet because like the other said it doesnt look like anything was gained -n00b
1993 25th Anniversary Edition # 156 of 301 ~ 121, 488 miles ( SOLD TO svxfiles 8/6/06) 2006 Subaru Impreza 2.5i....5spd - My daily driver 2006 Subaru Legacy 2.5i -7k miles..Mom's daily driver 2,543 Member of the SVX World Network |
PM Earthworm. He hosts SVX videos on his site: www.svx-iw.com -Chike P.S. For those wondering, here's a pic showing the hoses to disconnect after the car is warm. Doing this will allow for a rudimentary MAF bypass mod. However, if you do this understand that unfiltered debris can get into your engine, so using a some sort filtering screen/mesh will keep large particles out. P.P.S. I should give credit to Mychailo for the rudimentary throttle bypass mod.
"Wise men talk because they have something to say; fools, because they have to say something." - Plato 2013 Cosmic Blue 5spd Evo X GSR 2006 Galaxy Gray 6MT RX-8 (sold) 2006 Steel Gray WRX TR (sold) 1996 Brilliant Red SVX L (sold) Last edited by Chiketkd; 01-26-2006 at 02:34 PM. |
These show hp & tq in 2nd gear. With the rudimentary MAF bypass, he saw 175.03whp & 174.35 wtq, where my best numbers before were 165.1 whp & 173.4 wtq. Remember, this is an OBDII '96 so there's no Z32 MAF and Stage 2v5 software available yet from ECUTune. As a result, when peak power is made around 5,800rpms the power curve takes a dip and levels off. Previously, when I dyno'd this car and she didn't have the cams or my other mods, that dip didn't happen until 6,500+ rpms. With the Stage 2 software, I'm sure more peak power could be made when the maxed out MAF isn't an issue. The afr with the intake hose off is in the low 12.0:1 range which isn't bad, so the issue isn't fuel. -Chike
"Wise men talk because they have something to say; fools, because they have to say something." - Plato 2013 Cosmic Blue 5spd Evo X GSR 2006 Galaxy Gray 6MT RX-8 (sold) 2006 Steel Gray WRX TR (sold) 1996 Brilliant Red SVX L (sold) Last edited by Chiketkd; 01-26-2006 at 02:35 PM. |
cool, I was only seeing 165 for both, but i'm glad that everything worked well.
we're gonna miss you Chike
I'm just happy to see Kevin (Myxalplyx) continuing along the same path I was. Btw, the 175 whp (using the standard 30% drivetrain loss for an awd automatic) equates to an estimated crank hp of exactly 250hp! Again, this figure could be even higher once LAN releases the necessary MAF and software upgrades for OBDII owners. Kevin should definitely take his '96 to 14 seconds in the 1/4 mile on the motor alone. -Chike
-Chike
Beautiful. I wish more people put up a thorough set of dyno charts like these, with different gear pulls, and charts vs. rpm AND vs. speed.
Congrats on the great catch! Definitely looks like a blast to drive. |
I miss that car so much already. My wife said I cried more over selling that car, than I did when my son was born... -Chike
Hey Chike, Kevin, It looks like peak HP with the cams is at about the same rpm as the stock cams. Is that how it looks/feels to you also?
Mychailo :: 2006 Silver Mitsubishi Evolution 9, E85, 34 psi peak, 425wtq/505whp DJ :: 1995 Laguna Blue SVX L AWD 5MT (sold) Visit my locker SVX Mods: ND iridium spark plugs, Impreza RS fpr, afr tuned to 13.2:1 using a custom MAF bypass, custom exhaust, WRX 5MT w/ STi RA 1st-4th gear & stock WRX 5th gear, Exedy 13 lb flywheel & Sport Clutch, STi Group N tranny & engine mounts, urethane spacers in rear subframe, rear diff mounts, and pitch stopper, SVX Sport Strut Springs (185f/150r), custom 19 mm rear swaybar, urethane swaybar mounts, Rota Torque 17x8", 225/45-17 Proxes 4 tires, Axxis Deluxe Plus organic brake pads. Last edited by mbtoloczko; 02-23-2006 at 08:16 AM. |
Yes, I can take care of video hosting. I'll send you a PM with instructions.
Also, I do not know how this may help with the breakdown of hp and such but this is a graph I made up with Speed vs Time. It is the time each run took to get to the top of 3rd gear vs the hp it was making during this time.
